Old 01-24-2004, 05:20 AM   #1
sbmon's Avatar
Default whats best throttle servo?
what is the best servo for throttle applications?
alsoif you are using a servo with excessive torque
for throttle applications will this dump your rx battery
thank you
sbmon is offline   Reply With Quote
Old 01-25-2004, 12:26 AM   #2
Im2lazy's Avatar
Digitals obviously cause your batteries to dump faster and they cost quite a bit. For most, they are excessive for the throttle servo. Locally, a lot of people like the JR 4750 because it is coreless (great for the throttle return spring which you better have... since the servo is coreless, it doesn't take as much tension form the spring to fully return the carb to neutral), reasonably fast and has more than enough torque. The JR return policy is pretty good (and has a 3 year warranty I believe) and it has been pretty reliable.
I mean, it really depends on what is available to you, and what is your preference. I'd say get a coreless servo, with at least 80 oz. of torque and a speed less than .15 seconds. Get a servo on the slower side if you aren't the best driver at the track... get a faster servo if you feel you will actually notice the difference (obviously, be realistic). There are many models out there that meet this criterea, so your choices are quite open. But everyone's got their own opinion so talk about this to your hobby shop, or use the search feature on this site... you won't have to wait so long for more information.
Im2lazy is offline   Reply With Quote
Old 01-25-2004, 06:55 AM   #3
sbmon's Avatar
thankyou im2lazy
i will look into the jr you mentioned
i know digitals on throttle are not called for (especially with a 750mah rx pack) Your point with coreless i did not know/think of
that makes alot of sense to me so i will try to find something
coreless with bearings and middle of the road speed and torq (cause i drive middle of the road )
Throttle servo?!?! TeknikalMugen Nitro Off-Road 26 06-26-2008 05:10 AM
Steering servo and Throttle servo same speed? straightaway Nitro On-Road 4 11-06-2007 07:21 PM
vehicle stutters when i let off throttle? whats this mean? atebit Rookie Zone 5 10-03-2007 04:25 PM
Throttle servo gojoecrewchief1 Rookie Zone 5 09-14-2007 07:33 PM
Airtronics 94537 Servo Throttle Servo HS Imdadundada7 R/C Items: For Sale/Trade 23 06-19-2006 08:55 PM
SEO by vBSEO 3.5.0
