Weight Balance >
Weight Balance
Weight Balance
Old 08-10-2009, 05:55 PM
chromie's Avatar
Default Weight Balance
What can I use to measure weight balance on my 1/8th onroad cars?
I have a Serpent 960 and a MRX4X.
chromie is offline
Old 08-10-2009, 05:58 PM
clmbia45's Avatar
"Digital Weight Distribution Gauge" by Integy. Check with them about your specific application.
www.integy.com
clmbia45 is offline
Old 08-10-2009, 06:31 PM
www.integy.com
I don't see that product on their website, do they still make that?
yappy is offline
Old 08-10-2009, 06:38 PM
chromie's Avatar
Umm.. could I perhaps use the HUDY balance tool?
chromie is offline
Old 08-10-2009, 10:24 PM
nazwenhome's Avatar
Trader Rating: 33 (97%+)
just to share some findings. im not sure if its suitable to use X-ray nt1 tweak method, refer their setup book online. doesnt need much tools or get any value for balancing weight, but it will balance your chassis by tuning spring preload collar and anti roll bar.
just my 2 cents
nazwenhome is offline
Old 08-10-2009, 11:24 PM
Roelof's Avatar
If you just want to get balance use a tweakboard, if you want real weights get 4 pocket scales of 1kg.
Roelof is offline
Old 08-11-2009, 12:01 AM
nazwenhome's Avatar
i like that idea
Old 08-11-2009, 03:38 AM
freestyles's Avatar
Trader Rating: 14 (100%+)
I couldn't find it either
The hudy balancing tools are good but they will only tell you which way your chassis is balancing, to the left or to the right not what's at each corner or backwards and forwards. And can only be used if your chassis has two very small holes at the front and rear of the chassis for the point of the balance tool
Roelof, do you have to have your shocks disconnected to weigh each corner properly? And where did you get those scales and how much were they?
freestyles is offline
Old 08-11-2009, 05:39 AM
Roelof's Avatar
On this picture the car is standing on setup blocks and without the shocks you can see the balance in the anti rollbar.
These scales were bought for 12 euro a piece at a gadgetshop.
Roelof is offline
Old 08-11-2009, 06:09 AM
Trader Rating: 18 (100%+)
Default Weight balance
Try American weigh.com
brc358 is offline
