Old 01-19-2004, 08:59 AM   #1
Default Question about tuning....
I am trying to fully understand the Nitro tuning process (Again).
I have a Nitro RS4 3 SS, and I am having a bit of issues trying to figure out how to read the performance of the engine.
Here is what is happening...
It seems pretty punch off the line...but when it accelerates...about half way through...it starts to bog down...and then sometimes i cuts out...
Is the engine too lean or rich?
does anyone have any good Engine tuning reading (beside the stock info that comes from the Manufacturers)? I met someone this weekend...at a hobby shop that helped me out..but the weather has changed since then..and I need to do some fine tuning to accomdate the weather changes..
Thank you
UNITED_RC is offline   Reply With Quote
Old 01-19-2004, 05:55 PM   #2
mckrooz's Avatar
Send a message via AIM to mckrooz
What does it sound like when it cuts out? Does it make a gurgling sound or is the sound pretty high pitched? If it's gurgling, then you're too rich. If it's the other, than your'e too lean. It most likely will be too lean. That's when an engine will cut out when you're already on the throttle. Not enough fuel.
mckrooz is offline   Reply With Quote
Old 01-19-2004, 06:00 PM   #3
Almost certianly lean.
h82crash is offline   Reply With Quote
Old 01-19-2004, 06:27 PM   #4
That is what i was guessing...but I wanted to check to back up my guess.
I will try to richen out the high speed need and go from there.
thank you.
set up and tuning question Blisster Rookie Zone 2 07-31-2007 03:38 AM
Tuning Question ChrisE Electric Off-Road 3 05-21-2007 04:49 PM
SH .28 Tuning question Nickmind Monster Trucks 3 04-13-2006 08:47 AM
beginners question re: car tuning and motor tuning! Captjono Electric On-Road 5 02-19-2005 02:01 AM
Tuning question TRF-Powered Electric On-Road 4 04-08-2002 01:57 PM
SEO by vBSEO 3.5.0
