Futaba 3PK
Futaba 3PK
Hi
I have tried to adjust the \steering speed on the Futaba 3PK but even if I reduce it to 1% i cannot see any difference in speed.
When I change the throttle it goes really slow.
Does anybody else have this problem?
maybe your module is HRS, and your steering servo is not digital, and your throttle yes. Is that possible?
I have a 3pk PCM module with both digital servos futaba 9450 and they both response to the change of speed form de transmiter. Usually people play with exponentials instead of limiting the servos speed, for making the response smoother.
Both servos are 9451's. I usually set the exp to 70% on the steering.
Can you visibly see the rate change on the steering? What exactly do you do to change the steering speed?
