how many vent holes on your body do you cut out?
At my local track I see alot of people cut out 2-3 holes in the rear of the windshield at around 3 inch diameter. I have even seen people with no rear windshield Besides the hole on the front for refueling how many necessary holes should I cut out? Does anyone have an example of how they cut their vent holes on their car? I figure 1 in the rear so that the air can pass thru it and not let it cycle under the hood?
Ideally for maximum ventilation to the engine you should also cut out both front side windows.
Those and the big holes (hole in the rear window) will help keep the engine from cooking
How big of a hole shoud I cut out for the sides and rear? What if I cut out the whole rear windshield, would that be too much?
Super Moderator
Thanks for the picture
Re: holes in body
Originally posted by r12 schumacher
here is an example of a body (picture from forgass.org thanks jpilone)
Re: Re: holes in body
Originally posted by Sow&Steady
Glad to "see" that you switched back to Serpent!
Super Moderator
Re: Re: Re: holes in body
Originally posted by InitialD
Ummm, curious as to why he switched back to Serpent... I always thought r12 schumacher was a die hard Schumacher guy.
