Old 01-16-2004, 07:55 PM   #1
racer01's Avatar
Default Starting Problems
I just traded for a hpi nitro rs4-3. The glow ignitor heats the glow plug and ignites the plug, and the motor has compression. But the motor won't even try to start. If the fuel is old would the nitro have evaporated out of the fuel? What could be the problem?
racer01 is offline   Reply With Quote
Old 01-16-2004, 08:02 PM   #2
MugenMTX3Kid's Avatar
Send a message via AIM to MugenMTX3Kid
Try putting new fuel in, try richening the needle, make sure theres fuel in the engine....
MugenMTX3Kid is offline   Reply With Quote
Old 01-16-2004, 08:08 PM   #3
fmolzer's Avatar
Do all the coils on the plug glow or is the first one or two not glowing when you run a current through it? Sometimes, even if the filament is damaged, you can still run a current through and get it to glow at the bottom of the plug but it is still bad for performance/starting. Also, have you varified that fuel is flowing through the carb?
If your fuel is old I would try to get some new. You can store fuel for a year in a good sealed container in a dry, cool pace out of the sun, but fuel does go bad over time.
Good luck.
fmolzer is offline   Reply With Quote
Having problems starting my O.S Vpec in my Losi 8ight Please help NJA82 Nitro Off-Road 12 09-20-2007 04:18 AM
Starting problems Mikey. Nitro Off-Road 1 07-11-2007 10:53 AM
Starting Problems ICE77 Electric Off-Road 2 01-02-2007 07:02 PM
Starting problems ctmpwrdcamry Monster Trucks 4 08-12-2005 08:43 PM
Novarossi starting problems renjie Rookie Zone 6 10-16-2003 09:00 PM
SEO by vBSEO 3.5.0
