Centax Clutch
Old 01-16-2004, 07:30 PM
Default Centax Clutch
What does everybody uses to lube the trust bearing? ANd how often?
Thanks,
Steven Muller
MPP Team Palmaris Racing
nitrodude is offline
Old 01-16-2004, 07:34 PM
C Verano's Avatar
Default Re: Centax Clutch
Thanks,
Steven Muller
Ronnie Grease
C Verano is offline
Old 01-16-2004, 07:41 PM
I use Associated Stealth diff lube and I clean, relube and recheck the airgap on my centax every race.
I have since switched to a 3 shoe clutch and I am MUCH happier. Less damaging engagement, easier to drive on low to marginal traction surfaces, applies the power very smoothly and best of all... NO removing the clutch every race for maintainance!
NitroJohnnyD is offline
Old 01-17-2004, 04:16 AM
stefan's Avatar
I use that purple stuff that Trinity has. It's very sticky silicon grease that won't fling off as quick as other stuff...
stefan is offline
Old 01-17-2004, 12:23 PM
A-RASSS's Avatar
both paris green grease or loctite 8191(this one use by edo picco) works great.
Personally prefer locite 8191 as its easier to apply (spray) and it sticks the metal as it dries in few seconds, doesnt atract dust, a kind of coating, not conventional grease, keeps as part of the metal. When you touch it dont get your fingers dirty, as if you were touching the thrust bearing without grease. Also use by picco and salven to lube the CVDs.
A-RASSS is offline
Old 01-17-2004, 01:50 PM
C Verano, whats ronnie grease and where can I find it?
A-RASSS, where can I find locite 8191?
Thanks for all the replys guys.
Steven Muller
Old 01-17-2004, 04:24 PM
theRED5's Avatar
Ronnie grease is this green stuff that I think you can get at Ashford Hobbies . I have this stuff but like Stefan, prefer the Trinity Purple Stuff, it's much thicker and stickier and I think it stays on the bearing longer.
You should lube the outside bearing every raceday, and before the mains.
theRED5 is offline
Old 01-17-2004, 04:54 PM
EVOLUTION's Avatar
Mugen grease !
EVOLUTION is offline
Old 01-17-2004, 04:56 PM
Manticore's Avatar
Originally posted by EVOLUTION
Mugen grease !
it is "mugen super gease" !!
Manticore is offline
Old 01-17-2004, 04:58 PM
EVOLUTION's Avatar
I like to think it is "mugen stick sticky grease".
Stop lurking !
Old 01-17-2004, 05:07 PM
Manticore's Avatar
Stop lurking !
I wonder what reaction will the clutch be if you put such thick sticky gease in there.
Old 01-17-2004, 05:12 PM
EVOLUTION's Avatar
It will say thankyou for providng me protection and I say thankyou back cause I lube it once every blue moon or when it fails.
Old 01-17-2004, 05:19 PM
Manticore's Avatar
nah, i think with the thick gease, it will cause the thin shims slip.
the trust bearing wont fail easily unless you have too much end play.
Old 01-17-2004, 05:44 PM
C Verano's Avatar
Steven Muller
It's a green grease that is sold by Paris Racing.
C Verano is offline
Old 01-17-2004, 06:24 PM
quozl's Avatar
Any high temp molibdinum grease will do.
Tamiya, Mugen, Trinity, Paris they all sell it. You can get it a lot cheaper usually from specialty bearing shops just ask them for thrust bearing grease.
Cheers Alastair
quozl is offline
