Old 01-13-2004, 05:37 PM   #1
lachlan90's Avatar
tunning help
i have a bv1 and it has the os .15 engine. the running temp is 150F. what i cant seam to do is take of quick. it will always gurgle and then go. do i need to make it run hotter or should i tune the low end needle. i have seen peoples running temps at 230F is this alright. should i lean the high end needle more or lean the low end. im not sure if 150F is a low temp. is it?
any help would be great
lachlan90 is offline   Reply With Quote
Old 01-13-2004, 07:04 PM   #2
luketob's Avatar
Obviously your engine is set too rich, when the engine sets too rich, it'll bogs down when take off, when it's set too lean, it'll bogs down at high speed. Trying to keep your running temp between 200-250F. In your case, you need to lean out the needle setting (always start from high needle and work your way out from there). The character of your engine is depends on how you break it in. My NS12 engine runs great between 225-260. Hope this helps.
luketob is offline   Reply With Quote
tunning help, new c6 losiracer22 Nitro Off-Road 11 07-01-2008 09:05 AM
Tunning Bigwattsus Rookie Zone 1 06-19-2006 01:59 PM
tunning help kerry Electric Off-Road 2 03-25-2006 12:53 PM
tunning lachlan90 Australian Racing 3 01-13-2004 10:37 PM
tunning help lachlan90 Onroad Nitro Engine Zone 1 01-13-2004 09:14 PM
SEO by vBSEO 3.5.0
