Shepherd V8 '09
#151
I mean the first one, no euro conversion or 2010 kit, just the original kit.I think it's the 2008 kit.
Regds
Karl
Regds
Karl
#152
Suspended
In any case I would go for the 2009 upgrade set with a new pulley-set. The only tip I can give is to use the 2-speed brace.
#153
A quick one, just set the car up ans it seems pretty soft? Blue springs and 650, shouls I go white first?
#154
#155
Hi Guys,
Ran a Test day yester day the track is similar to cordoba in that , it's a fairly easy layout,but Hard to go Fast, The chassis was good using the Volta Setup as a Baseline, I think I can Spring Up, to make it a little more direct, I was running the Blitz 06, and i saw the Fast guys were running the Blitz 09 body,so i am mounting one to try.
I am battling a little with the motor Clutch Setup, but am going later this afternoon to try and work on it a little more, and see whether i can get Some fighting fit Stallions to pull my Wagon.
Any clutch setup tips would be greatly appreciated.
Also i think I am Geared a little long in 1st running 16/50 . Does anyone Know if shepherd Make a 15 T pinion? At 5,500 ft here the motors strain out of the corners.
Karl
Karl
#156
Suspended
#157
Hey guys, been running the velox for a short time and noticed the bearings are sitting loose in the front and rear hubs??? Think its original plastic and not sure if there is a update?
#159
Suspended
#160
No its the normal bearings, my friend had the same issue and changed to the small bearings. Is this the solution? Yes uprights.
#161
Setup Velox
Hello,
I need some help on the steup of the front. So far the front of the car is slow to react.
As a starting point i used Richard Volta from the shepherd web site
The only difference is the position of the front wishbone position that I set at low position.
To make it a bit more reactiv I move from 4mm to 6mm front upper arm position and rise the anti roll bar.
These changes make the car turn a bit better but not as much as I would like.
I would like the front to turn more like a 1/10 elec DTM on carpet could do.
I was thinking about reducing the track width.
Any idea to improve the setup of my velox?
#162
Hello,
#163
#164
#165
Hi Pooh, did you switch from Mugen to shepherd? What are the choice bodies to run, I have a central but the car does not seem to like it, thinking Blitz 09 or P909?
Cheers mate
Cheers mate
