schumacher nitro fusion
hi id like to buy some new stuff for my car ie tuned pipe,air filter
but all the 21 stuff is for off road cars and trucks and my car is on road and has a 21 engine can i still get the parts even if its a on road car
well When there say it is an offroad pipe usually it is tuned to make the most useable power in an offroad condition. Also some off-road pipes will just be to long to fit your car. Check out rb concepts. They have some nice pipes. Even if you go with an x15 turbo you will see gains over that soda can aluminium pipe from the factory.
will you post a link plz
http://www.rbproducts.com/rbww/pipe_manifolds/2.5cc.htm
#1850-T (X15 Turbo Pipe)
Will give best power for your .21 powered 1/10th scale.
Since your car is only 1/10th, it will not accept .21 size pipes, as they are too large, and will not even fit.
You will most likely have to angle the X15 pipe upward a bit (use longer retainer wire) to get the pipe to clear the front left wheel.
You cannot use any of the .15/.12 size manifolds on the included .21 engine.
In the future if you decide to replace the engine, look for a big block .15. Lighter, and a more even power-to-weight ratio.
so if i go for that pipe will i still get the same if not faster speed out of it
