HPI PROCEED questions
#16
thanx for the tips on the tires, and let me know fellas what you want for those parts and for the belts and roller, thanx
#17
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
#19
i talked to a friend of mine at a race today who also has proceed parts, i think he has arms and shocks and things like that, ill get the info from him tomorrow on what hes got and see what you may be interested in if youd like
#20
yes, that would be awsome, ill buy whatever he wants to sell, or ill buy them all. thanks very much for lookig out, thats cool of you. keep me posted
#21
sweet, ill give him a call tomorrow and get a count on what hes got, hes not very computer savvy so i think illl be his middleman but ill do what i can for ya! lol ill get back to ya tomorrow
#22
Hi There,
I'm sure you can find some pare for this great car.
For the front wheel, Mugen/Kyosho wheels can fit, you just have to reduce the axle kingpin length of 2mm. Recent Serpent wheels can be adapted without any modifications, same width.
To reach a correct rear width with Mugen wheel, you must put the plastic thick washer (or aluminium version you have this option) in front of the inner bearing.
(first on the wheel shaft) instead of on the outer side.
Then, you also have to cut a bit the rear upper arm and screw it without any camber extra washer.
Some HPI R40 or Nitro3 parts can also fit the shock absorber body to mount a ball end instead of the kingpin cap which stucks the suspension freedom once you tight the M3x3 screw.
R40 alu pinion gear also fit the Proceed clutch bell. Very useful on small tracks as the smallest 1st pinion is only 17teeth. R40 starts at 15teeth.
I also know that the R40 complete gear box can also fit after few modifications. But the standard one is ok, a bit heavier but ok.
Last tips, you can adapt a big black Kimbrough servo saver instead of the standard one which "delay" the reaction a bit.
PM me if you want some pictures.
Cheers
Slide
Cheers
Slide
#23
psycolosidude, you have pm
#24
bunch of proceed stuff
I too have quite a bit of proceed stuff.......complete car and some tires and spares. I also know someone who had collected a bunch of rims but you would have to mount the rubber. My car had a few Delta upgrades and the car was good. PM me if you are interested and I can get it out and give you a better idea of what I have. Have a good weekend.
#25
I have another question, can any of you guys tell me the sizes of the belts on your cars plus tooth count. example- front 6mm-67tooth. middle 6mm-144tooth. rear 8mm-70tooth. those are my proceeds specs. thanks, i just want to see if i can use other companys belts
