Mixing oinions and purs from different sets ?
If keep the stock 15T pinion with the stock 51T spur for the first speed, and change the second pinion from 17T to 21T and replace the second speed spur as per the intructions from the stock 47T to 45T
So I will go form using the stock config wich is
15/51
17/47
to using keeping the first gear stock and using an the second speed gears from an optional set to have:
15/51
21/45
Will that work?
In other words I am only changing the second speed gears, my car is a TG10R
15/51
17/47
15/51
21/45
Will that work?
