high speed needle vibrating loose. screw backs out.
Engine has been running like a champ until last Saturday...
To my suprise I noticed the highspeed needle moving while at 1/2 throttle on the bench... basically vibrating loose to an extremely rich setting...screw is backing out on its own..
WTF... I am new to nitro and know that cannot be good...
So what is the fix? new needle?
Thanks for the help.
High speed needle
What motor?
i had the same problem but both the low speed and high speed did the same thing, i called kyosho and they told me that the o rings that were used in that motor were defective and they know about the problem , they gave me a part number for a the o rings it comes as a carb maintance kit
(KYO74023-17 ) hope this help PM me if you need more help i been through this for a while
Meanwhile you can cut a small piece from a fueltube to use as O-ring. Most of the times this will work.
True, put a piece of fuel tubing on my sons GT1 at the KC HOA and have not had no problems since then.
