Team Magic G4RS 2009
#917
Imapala..
Just looked at the results.. not a great time on track I assume.. Thank heavens for round 4, the other rounds seemed like you had problems and that DJ driver is over 1 second faster compared the majority of the field.
Finals... a few long laps, is that due to the race timing system or something, blanks mean being lapped ? Or did you have problems? Flame out at the start too??
Couldnt see much of the track, what was the surface grip like, that sweep looked mighty fast... Springs? Tyre Combo?
Regardless, close racing in the B main well done..
h
#918
Problems
I was sitting here in Aus, Saturday 3am and I see your name appear on the results page and woudln't ya know it... the live system locks up on your race..
h
h
Front
Track Width-197mm
Rollbar-0
Solid Axle
Toe out-1.5
Camber L-2 R-2
Ride Height 5.5mm
Droop -2mm
Caster-3mm
Tire Twister -40 shore 59mm
Spring -Kyo Darkblue
Shock oil-Kyo-500wt
Piston 2hole 1.1mm
Ackermann -C
Rear
Track width -199mm
Rollbar-2.2
Diff 80,000
Toe 2.0mm
Chamber L -4.0 R-3.5
Ride Height-6mm
Droop 3.5
Tire Twister 42-61mm
Spring-Kyo DarkBlue
Shock oil- Kyo-500wt
Piston -2hole 1.1mm
Wheelbase 258mm
Body Stratus 3.1
Gearing 16/63-22/57
Engine Murnan RbM3
Header 5fin -Nova
Pipe-Nova 2630
#919
Suspended
BLANKS LOL
Boy let me tell you about problems,the blanks are when u have car problems first my car was destroyed ,so i did this race with a borrowed car, that i had really no time to find the right setup for my driving style,so i had to wing it, an i did it in the 4th round, with a used X-RayNt 1.My car was unrepairable bent chassie ,so i worked with what i had an to beat all the whole layout was changed so had to learn the car as best as i could .With all said an done i made the top 10 out 46 sedans in our points series.But when i had my G4RS 09 on the track it was dialed heres the setup i would have run
Front
Track Width-197mm
Rollbar-0
Solid Axle
Toe out-1.5
Camber L-2 R-2
Ride Height 5.5mm
Droop -2mm
Caster-3mm
Shock oil-Kyo-500wt
Piston 2hole 1.1mm
Ackermann -C
Rear
Track width -199mm
Rollbar-2.2
Diff 80,000
Toe 2.0mm
Ride Height-6mm
Droop 3.5
Spring-Kyo DarkBlue
Piston -2hole 1.1mm
Wheelbase 258mm
Body Stratus 3.1
Gearing 16/63-22/57
Engine Murnan RbM3
Header 5fin -Nova
Pipe-Nova 2630
Front
Track Width-197mm
Rollbar-0
Solid Axle
Toe out-1.5
Camber L-2 R-2
Ride Height 5.5mm
Droop -2mm
Caster-3mm
Shock oil-Kyo-500wt
Piston 2hole 1.1mm
Ackermann -C
Rear
Track width -199mm
Rollbar-2.2
Diff 80,000
Toe 2.0mm
Ride Height-6mm
Droop 3.5
Spring-Kyo DarkBlue
Piston -2hole 1.1mm
Wheelbase 258mm
Body Stratus 3.1
Gearing 16/63-22/57
Engine Murnan RbM3
Header 5fin -Nova
Pipe-Nova 2630
I never seen a car so wrecked he broke some crazy shit
and I never seen anybody switch raido gear from one car to another
that fast. but I still think BW was faster in his G4.
#920
rear adjustable sway bar
Hi,
Does any one knows if there will be an adjustable rear swar bar for this car?The stock sway bar rubs on the rear bulkhead alot and thiis tweaks the car.
#922
thanks,but what about optional sway bars.
#923
#925
Hi Grouchy where are you located?
Im in sydney australia and our local distributor has most of the kfactory upgrades in stock.
visit www.nbhc.com.au
Im currently testing the front adjustable swaybar and next weekend ill be tetsing the thicker rear sway bar which is 2.4mm.
#927
Sways...
Ari should host a TM event there.. count me in if he does.... "The Mafia" Challenge!!!
#928
John, try something for me one day at Moorebank. Slam on the stiffest springs, lower height and reduce droop, 42-45 sh / 59-61mm and give me some feedback of what you think. The RS09 with it's wide arms and FLEX chassis should in theory be a much stiffer suspension setup, specially at Moorebank. (For Int'l racers - Moorebank has the silkiest smooth surface and curbs that are deliciously tempting!)
we dont have the numbers on club day for that sort of grip
ive been running 37s all round with a 42 rear in the final. i have a list of things to try so i might try and do a test and tune day one day next week.
#929
cheers John..
Sorry I mean 42's or 45's... I was surprised how much grip we had even at the NSW when track was green. Aero really works well at Moorebank. Anyways.. just throwing ideas into the TM think tank.
h
