Team Magic G4RS 2009
#541
i have to agree on 08 tweaking problems and wc upgrades. seriously cant wait to assemble my new RS.
just wondering, i was planning to tear down few parts from my front Wc upgrade . does the G4+evo front top alum brace fit? what about the hex hub?
#543
had my frist race with the car today and it was not to bad. bobby watson and i are working on the cars setup and it going well. bobby's car was looking goooood i just need a little more track time and some motor
i love this car, thanks machinaria for the great deal on the car
by the way we have just received the Kfactory upgrades tell us what you guys think about them.
Best regards
www.machinaria.com
#544
I like your work
You want a Mugen ? - I have one for sale ! LOL!
Harry, we only ran 3 heats and a 15 min final the weekend before last , that was enough to convince us to stay with TM...however I like the flex concept, very easy to remove 2 screws and have this...We really haven't had enough time with the '09 to test this yet.
The 4mm chassis is so much better than that "thin strip of aluminium foil" that was called a chassis on the RS08 that it's not funny...
It looks like now you don't need to check tweak after every run...no wonder TM released the WC kit for the RS08...
Ball ends , arms , actually all parts are a lot smoother fitting than the old car I was explaining to a mate, the difference between them (08 & 09) is pretty big....not just the looks.
Imagine having the drawings and concept to build a supercar - you give 1 set of plans to Daewoo so they build it , then give the same set to Ferrari, Mercedes Benz or BMW - similar concept, totally different outcome....
The RS09 seems - very strange to say this and I'll probably need to wash my mouth, "Xray-ish".... you'll see what I mean when you work on the car....excellent parts fit etc and best of all, works well with a kit set up .
Cheers 2 Brendan as well...
One day Ill we hope to get down south and play Lola 1:10 with you both..
h
#545
Diff Setup for SS Hobbies of Tampa
Front setup
Track width-198mm
Sway bar-0
Diff 200,000
Toe-+1.5
Camber 1.5 L&R
Ride Height -5mm
Droop-2.5mm
Caster -3mm
Tires Jaco 40- 59mm
Shock oil 600
Springs- Kit
Rear Setup
Track Width-200mm
Anti Roll Bar-2.2
Diff-50,000
Toe 2.5
Camber 4.0L-3.5R
Ride Height 5.5
Tire Jaco 42- 61mm
Shock oil- 600
Springs-Kit
Body -Stratus 3.1
Wheel base-258mm
Engine- Picco Evo3 Blue Head
Pipe & header -Picco
Gearing-
16/63
22/57
Clutch- X-Ray
Tire wear was really good ran 1 set all day.
#546
WOW!!!!!!!!
I have installed ceramic bearings and aluminum hexes and WOW!!! my car was going so freaking fast I could not stop it!!!
make sure to adjust your break link after changing bearings and hexes
#548
Thanks Randy, im gald i dropped that Picco Evo3 in for the main,also with the front diff the car was real easy to drive.Here is my diff setup
Front setup
Track width-198mm
Sway bar-0
Diff 200,000
Toe-+1.5
Camber 1.5 L&R
Ride Height -5mm
Droop-2.5mm
Caster -3mm
Tires Jaco 40- 59mm
Shock oil 600
Springs- Kit
Rear Setup
Track Width-200mm
Anti Roll Bar-2.2
Diff-50,000
Toe 2.5
Camber 4.0L-3.5R
Ride Height 5.5
Tire Jaco 42- 61mm
Shock oil- 600
Springs-Kit
Body -Stratus 3.1
Wheel base-258mm
Gearing-
16/63
22/57
Clutch- X-Ray
Front setup
Track width-198mm
Sway bar-0
Diff 200,000
Toe-+1.5
Camber 1.5 L&R
Ride Height -5mm
Droop-2.5mm
Caster -3mm
Tires Jaco 40- 59mm
Shock oil 600
Springs- Kit
Rear Setup
Track Width-200mm
Anti Roll Bar-2.2
Diff-50,000
Toe 2.5
Camber 4.0L-3.5R
Ride Height 5.5
Tire Jaco 42- 61mm
Shock oil- 600
Springs-Kit
Body -Stratus 3.1
Wheel base-258mm
Gearing-
16/63
22/57
Clutch- X-Ray
What brand of 200,000 wt silicon are you using for your front diff?? XRay??
Now that the high grip clutch shoe came out, will you give it a try??
Thanks!!
#549
We are glad to hear the good news, keep up the good work
Best regards
www.machinaria.com
Best regards
www.machinaria.com
#551
#554
Please let us know if anyone is having issues ordering, Paypal was having system issues today.
Best regards
Anna Arze
[email protected]
www.machinaria.com
Best regards
Anna Arze
[email protected]
www.machinaria.com
#555
Cant blame the guy..
I was caught up in meshing gears and dropped a pinion and it leaned us out.. 14 year old gave dad a well deserved serve...tail between my legs.. yes... still learning.
It was more a matter of no TM support and can understand his shift. There was 2 more seconds in his car at least. What he's gonna tell his wife when he says I want to sell Xray and buy the 09...would be more difficult than getting a G4+ sorted out so I wont be hassling my NSW garage buddy even if he is a TRAITOR!!!! I have a few spare TM stickers we can put on his shell.. that'll make it go faster!
joking about traitor..
h
