Old 06-16-2009, 09:09 AM   #1
Default gear mesh problem
hey guys,
my gear mesh has been good for about 2 months, so i took my engine out to clean it the other day and when i put it back it i thought it was as close as it was before but i ran it and stripped the 1st gear spur gear, so i had another one and made it a tighter mesh and it ran for about half tank and then they started to tear up the gear ... whats causeing this?? and is there a gear mesh base line?
Hpi R40 Hara w/ .12JLR
Hpi R40-rolling frame
Tamyia F103 LM -Ole school
soon a 1/8th on road
Duratrax Maximum ST Pro
Hpimichael is offline   Reply With Quote
Old 06-16-2009, 01:47 PM   #2
cobrajet's Avatar
Us a sheet a paper to set the mesh. Plus check your clutch it may be getting too hot. Parts do wear check your gaps regurly. And draging drive train can do the same.
Oh and check your bell. It may have a lose gear or pull on it and see if it is crossing gears and rechim it if it is
Serpent 733
Serpent S120
Hpi Baja 5T
cobrajet is offline   Reply With Quote
Old 06-16-2009, 07:25 PM   #3
Trader Rating: 47 (100%+)
Your problem may that one or both clutchbell bearings
are worn out. They take alot of abuse and should be
checked often.
rageworks is offline   Reply With Quote
XXX-NT AD2 Thread DemonLosi Nitro Off-Road 2219 10-05-2016 05:56 AM
Losi XXX-S TSR6 Electric On-Road 14329 01-26-2015 07:59 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
2nd cracked case.. engine mount problem. any suggestions? builtb16a Nitro Off-Road 39 08-15-2009 12:44 AM
Project Team Kassanova TR3 V2 (Tc3 Truggy) eds24 Electric Off-Road 28 06-28-2009 09:20 AM
Kyosho Inferno GT2 part Bullz Nitro On-Road 23 01-13-2009 05:34 AM
RC10GT Gear clearance catchs stones??? CDG Electric Off-Road 18 10-24-2005 10:20 PM
SEO by vBSEO 3.5.0
