need help
need help
im haveing problem with my xray nt1. the clutch preload adj. nut keeps winding it self on dont no if i should use more shims an adjust the end play or clutch gap or behind thhe flywheel im useing an os tg motor can any 1 help
ok thanks ill give it a go tink its cause i lost a ball out of thrustbearing 2. ill wait till i get new 1 then rebuild it
