Serpent 733 1/10 200mm touring
#3527
As for over tightening the screws i think the thread would pull out of the plastic gear before applying enough force to crack the ally.
Hopefully just a rouge component?
#3528
Hi Guys,
Ran my 733 evo for the first time yesterday and was very impressed,
Run the car again today about 10 laps in lost drive and once i collected the car from the infield had a quick check found the aluminium oneway hub that holds 1st gear had cracked thus releasing its hold on the oneway bearing!
Is this common, will i need to carry plenty of spares or is there a fix?
your is 733EVO , so i'm think do you have drop oneway oil in oneway bearing ??
#3529
We long time no receive this case ,
but you can contact your seller !
#3532
hi there, can anyone tell me the difference between the short springs and the rear springs. can the short springs be used on the rear or do you have to use the rear set. thanks
#3534
Hi guys, after striping a few second spurs, i suspected a faulty one way, so i got the new orange one (pro), was told that i didnt need to put oneway lube on the bearing, are these bearings pre oiled or something and what bout after a couple of runs, should i still not oil this new oneway.
#3535
#3536
Car runs quite smoothly, the reason i suspectd the oneway was that the chnge from 1st to 2nd was not smooth, looked more like it was snapping into second gear, wen i lookd at both stripd gears, both had about 3 or 4 teeth that were completely taken off, like wen u pick up a stone, and the rest were just flattend.
#3538
lets hope it was a stone then, if it wasent then there is something wrong with how the car is setup... make sure the 2speed axel dosent move left or right, make sure there is no play at all left or right... you may need to rebuid
#3539
Just rebuilt the car befr this, 2 speed shaft is solid no play at all, the reason i ruld out a stone is that it happened twice on the same day, exact same strip on the gear, couple of teeth taken right off and the others just flatend. 1st gear was perfect, no wear at all, which lead me to thnk that the 1st was maybe still engagd wen the 2nd came in ie oneway nt releasing 1st.
#3540
1. Check you have enough "clearance" between the 1st/2nd gear pinions and spurs. I am referring to side movement (endplay) not mesh. You will notice that if your flywheel is not shimmed correctly, and you have alot of endplay on your clutch, the 2nd gear pinion will actually touch your 1st gear spur. I have seen a few gears strip spurs like this.
2. Check for wear and movement in your 2speed bulkheads. These tend to wear over time, cause bearing and shaft movement and vibration.
