Serpent 733 1/10 200mm touring
#2671
This Titanium pillow balls http://kamikazercracing.com/proddeta...=SER808348-733 have been put to test in a 966, it had survive a complete left side suspension wipe out where the Original steel one normally bends after impact.
#2672
what is the DIFF from the stock 733 clutch and the xceed clutch on serpents site?
#2673
mouting p56
guys any suggestions/tips in mounting a p56 body? should i start putting the holes from back, then front ? do i have to modify rear body post so i wont hit the wing part? ty
#2674
I always mark the front first. Make sure the cut line at the bottom is parallel, or level, to the work surface, as it will sit on the car. In most cases the front body posts will contact before the back. Do not place the body so that both front and rear posts are touching. Mark and cut the front holes first, then put the body back and mark the rears. If you mark the front and rear at the same time, it will shift the body forward. Remember to keep the body level when marking the front. There is no margin for error, take your time, it is a tedious body to mount.
The bumper may cause some difficulty. The nose is very short. Remove the foam from the bumper to make sure there is no interference. You can shape the foam afterwards if it is a problem. The rear posts will cut into the wing mounts just slightly.
Ran mine for the first time last weekend and I love it. Feels like the next generation Stratus. Good luck.
#2675
GLC
can someone of post GLC setup from serpent driver or link ?? Going in Aug trying to get ready now..
#2676
I ran the Nats there last year and I ran the box setup with some changes.
Front diff=200K
Rear Diff= 80K
Wheel base 2mm short in rear/ long up front
I started with 37f/40R tires (I ran 40/42 in main)
1 hole piston front/ 2 hole rear 1000w oil.
Blitz Altis 2.3
Hope this helps
#2677
The guys that have those setup sheet are currently at the worlds. I've never seen a published sheet from them for that track.
Front diff=200K
Rear Diff= 80K
Blitz Altis 2.3
Hope this helps
Front diff=200K
Rear Diff= 80K
Blitz Altis 2.3
Hope this helps
#2678
Looks like we are going to get a lot of new goodies after the Worlds...
Look at this:
http://www.serpent.com/news/13127/US...LS-system.html
Looking at the photo of the car, it looks like it is a team drivers car, I can see the white "prototype" spur gear, the belts look different, looks like the optional brake disc is on it.
Look at the number of shims on the rear arms
Look at this:
#2679
Look at this:
Look at this:
#2680
Wondering what it does when you get a hit on the rear wheels?
#2681
#2682
Read all about it here:
http://www.rctech.net/forum/nitro-ro...DAX+suspension
mod to a 1/8 mugen if i remember correctly.
#2683
This is Michael Salvens car. I have seen him drive this configuration just before he left to the USA. I was wondering then why he did not drive with a rear stabi, but this explains a lot.
#2684
About the rear stabi you can read the working here:
http://www.daxcars.co.uk/anti-roll-suspension-03.htm
#2685
Interesting material Roelof, can't wait for them to come back from the Wild West, to see if I can get an hold on one of these.....
