Serpent 733 1/10 200mm touring
#2551
...a little leakage in one of my diffs as well...brand new.
I`m trying to find the Orange Serpent colour (limited stock of paint in the shops here in Norway).
I`v bought 5 different ones, and they all are awful.
Can anybody guide me to the correct colour.....
Best Regards
Noooob
Best Regards
Noooob
#2552
Hi!
Looks to be quite similar to the colour on the logo on Serpent homepage.
Have not seen Faskolor in any of the shops in Norway.
But as I said, the stock in the shops are very limited.
Thanx!
Best Regards
Noooob
Thanx!
Best Regards
Noooob
#2553
Best Regards
Noooob
Best Regards
Noooob
i never used a diff long enough to notice any alignment problems. i did notice some with a car here at the WA states. was a lack of use of the plastic spacers between diff and bearings. a spool is a nice fit and guides the belt better. with the diffs, i really think its the design that catches people out.
when assembling them, diff fluid gets in the tubes where the screws go, and fills them up, and when the cases compress, if you have the pulley on it, a fair bit of diff fluid gets caught up. i really think its a weapage of the diff fluid coming out around the screws, and leaks down to the joint if left sitting for a while in one spot. i have used sealant on the diff o ring, and i try to clean out the pulley screw side of oil, as i think it compresses so much and stresses the plastic tubes as well when fitting the remaining screws for the pulley. Just my thaughts , regards, Patto.
#2555
Best Regards
Noooob
Best Regards
Noooob
#2556
One thing i done that has helped me with leaking diffs is making sure that there is no excess flashing of plastic at the end of the tubes that the screws go into. i found they were slightly uneven on my diffs which caused the diff housings to not seal against eachother properly when tightened. i carefully dremelled a small amount of excess flashing from the end of the tubes and since doing this my diffs have not leaked at all.
#2557
Though not practical but I was thinking if serpent could make a metal diff casing? What u guys think? Would be a nice piece of machining
#2559
Regards
#2560
Thanks for the help guys looks like i'm on top of it now.
#2561
Thanx for helping.
Ass. colours are now orderer.
Great forum!
Best Regards
Noooob
Great forum!
Best Regards
Noooob
#2562
need battery
hey guys,
I bought a used 733 and it did not have the battery. Anyone know where i can order one. I tried looking on serpent's website but i can't find one.
thanks
thanks
#2565
battery
thanks
