Serpent 733 1/10 200mm touring
#2206
In my entire RC life experience, I have never seen a pin on a dogbone or driveshaft break at all. Usually the part that fails is the out drive or drive cup that receives the dogbone/driveshaft is the one that would fail in breakage of the outdrive or severe wear, hence the need for the plastic blades on the pins.
#2211
Guys, why use low-profile servos in case of 733 I wonder.
#2214
Is there a lightened middle pulley shaft?
#2217
Hmm will it be CSO?
