16% 20% 25% Nitro content??? >
Old 05-23-2009, 09:45 PM
  #16
afm
afm's Avatar
Originally Posted by GREGORY!
in the real world (bikes) i give advance and i have torque but lacks rpm.
i give retard and i have rpm but lacks torque.
i don't talk about huge difference in degrees.and of course there is not any detonation.
in the first occasion the ignition is created sooner and you have great performance in the low rpm.but when the rpm increase the dynamic compression is increased and in interrelation with the advanced ignition you have an engine that actually it 'tightens' in her own.
so still can't understand why here is the opposite.
Although you can't measure or definitively set when ignition takes place inside a nitro engine, it helps to be able to visualize what's happening when you experiment with different plugs. Let's say, for example, that the fuel mixture is ignited precisely at the moment the piston reaches the very top of the cylinder. This would effectively mean the ignition timing is taking place at zero degrees of crankshaft rotation. Installing a hotter plug in the same engine makes the fuel ignite sooner because less compression is needed to heat the plug's element to the point that the fuel will ignite. Let's say that now, ignition occurs 10 degrees before the piston reaches TDC. In ignition-engine-language, that would mean that the timing is set to 10 degrees advanced, or 10 degrees BTDC (before top dead center). What does all this mean? Simply knowing that plug temperature will affect when combustion takes place and will, hopefully, help you understand why choosing the proper plug will improve performance. Generally, it's best to try to advance the timing or flash point of the fuel—in the case of nitro engines, as much as possible without going too far. If the mixture is ignited too early, then performance is lost and pre-ignition and detonation may occur., because the more nitro you run, the more you advance the ignition point. What's that mean? In an ideal situation the glow plug will ignite the air fuel mixture when the piston is at top dead center (TDC), which will force the piston down and back up for another compression stroke. When you run a higher nitro percentage (and don't go to a colder plug) you'll advance your ignition point (the point at which the glow plug ignites the air/fuel mixture), which will result is less than optimum performance since the piston is still on it's compression stroke when the air/fuel is ignited and not at TDC.
AFM
afm is offline
Old 05-23-2009, 11:36 PM
  #17
NitroWD's Avatar
16% gives more rpm than 25%; by how much?
25% gives more torque; by how much?
anyone?
NitroWD is offline
Old 05-24-2009, 03:38 AM
  #18
Nitro-Racer*'s Avatar
great information!!
Nitro-Racer* is offline
Old 05-24-2009, 08:59 AM
  #19
GREGORY!'s Avatar
AFM
i agree with you.
if you want to know we had a lost of 40+hp [high rpm]in a 1600cc tyrbo engine [400hp] in the dyno for only 2 degrees advance.with NO detonation.i want to tell with this that there is a specific range that you can play with advance for more power.
also i want to tell that the ignition in these little engines is not steady.it will start quicker as the rpms increased.
as for the plugs i will try myself to see whats going on.
GREGORY! is offline
Old 05-24-2009, 08:27 PM
  #20
afm
afm's Avatar
anyone?
Very difficult to quantify in numbers without a Dyno...but trust me, you will notice the difference, everything else well set.
AFM
afm is offline
Old 05-24-2009, 09:45 PM
  #21
asw7576's Avatar
Originally Posted by lil-bump
I would not worry about changing Nitro % based on weather conditions. If anything I would maybe change the heat range of the plug. I only do this if the weather takes a big change from qualifing day to main day. On very humid days I might go to a slightly hotter plug. I normally use cold plugs also with 16% fuel I normally use a Med heat plug just to give me a little better bottom end.
Pass you soon...
When humidity comes on the scene past 70%, it is best to move to a hot body glow plug. For example in your first case move to a C7TC, and I would not increase nitro. I think the C8TF is way to cold for a .12 engine and is best used with 30 to 40% nitro on a very hoy day.We should also state that without touching head shimming, and or cahnging nitro contents, a hotter plug will make the engine rev harder and a colder plug will make more torque.
The atmospheric pressure, temperature and humidity all affect the density of the air. On a hot day, or at high altitude, or on a moist day, the air is less dense. A reduction in air density reduces the amount of oxygen available for combustion and therefore reduces the engine’s horsepower and torque. For tweaking the fuel/air mixture and compression ratio, the air density is the most important consideration.
Inputs:
The Air Temperature should ideally be the temperature of the air that is going into the intake of the engine.
The Absolute Pressure (also called actual pressure or station pressure) is the ambient air pressure.
Relative Humidity is a measure of how much moisture is in the air compared to the amount of moisture that the air could hold at saturation.
Relative humidity is a function of temperature and therefore changes as the temperature changes, even if the amount of moisture in the air remains constant.
The air density is the actual weight of a given volume of air. This is a key parameter for engine tuning.
When the air density increases, you will need to richen the air-fuel mixture to compensate. When the air density decreases, you will need lean-out the air-fuel mixture to compensate.
Use the following as a guide to correcting your setting when the weather changes:
Air temperature: When the air temperature increases, the air density becomes lower. This will make the air-fuel mixture richer. You must lean the mixture to compensate for the lower air density. When the barometric pressure decreases, the opposite effect occurs.
Humidity: When the percentage of humidity in the air increases, the engine draws in a lower percentage of oxygen during each revolution because the water molecules (humidity) take the place of oxygen molecules in a given volume of air. High humidity will make the air-fuel mixture richer, so you should lean the mixture.
Altitude: In general, the higher the altitude the lower the air density. When driving at racetracks that are at high altitude, you should lean the mixture and increase the engine's compression ratio to compensate for the lower air density.
Hope this helps
AFM
Thank you friends,
This is very good reading and knowledge for all of us.
I end up using the same 20% nitro and C7TF. The weather turn out to be relatively fine on saturday and sunday. I finished C4. Well, I guess that was my limit...... I already give my best to bring my car to the finish line with sweats, nervousness and hands shaking.
The winner from Futaba Jakarta Open 2009 :
1. Danny -- local, xray international team driver
2. Steven .....novich from Australia -- Novarossi team driver
3. Sadikin -- local, xray international team driver (TQ)
Sadikin was A1 and TQ , and most people bet on him to be the winner from this championship. He is aggressive driver with speed, speed, and more speed in his mind. Too bad he had to change the rear tires twice !!! Blame it to his mechanic to put used tires when his 2nd spur gear was out.
Steven from Aussie land was consistent and perfect racing driver from the start. He stay away from trouble and he was passing others smoothly, except his speed is not there.... I guess if his speed was faster, he can finish 1st.
Daniz24 was luckyman ( or clever on tire choice ). While some drivers were fighting with tire loss traction after minutes 30, 35, 40. Danny didn't have this problem all the way to 45 minutes. His pitting time is short, consistent and no mishap. So good pit strategy and consistency lead him finished few seconds ahead than Steven.
And there were many top drivers from Malaysia and Singapore ( Jesse Wu ) showing their best racing performance during the race. The race were intense with close number of lap times and most of them were all able to complete the 45 minutes race. A full race report maybe release in xray website sometime in near future.
asw7576 is offline
Old 05-26-2009, 12:27 AM
  #22
keavze's Avatar
AFM
more nitro and hotter plug will advance the ignition point till maybe too early and detonation occur, can i increase the deck height (reduce compression) to 'compensate'?
by the way, how to tell if you've retarded the ignition too much?
i know if you've advanced the ignition too much, detonation will occur and you'll get pitting on the piston and button.
keavze is offline
Old 05-26-2009, 01:52 AM
  #23
Big Lee's Avatar
Default Changing fuels
AFM you are the bomb. Great wealth of knowledge.
MY question is : I race offroad buggy with a .21 GRP tuned mill and have been running 20% Nitro ( Oils - 10% Synthetic, 5% Castor ) and an O'Donnel 97T (medium) Plug, with good results. Was lacking bottom end so went lookig for answers and found RCTECH and the wealth of knowledge to go with it.
Since reading the GRP thread have learned that the usual tuning meathod of tuning the hsn first then the lsn was not a good way to tune these motors, that they loved having a rich top end and very lean bottom. WOW what a difference. Still working on the tune.
Thinking of uping the Nitro content to 25% as used by the majority of racers at the local club. Was lead to beleave early in my rc life that past 16% was only decreasing the life of the motor, so was always hesitant to go any higher than the 20% originally recomended by my lhs when I started out.
BUT these motors come head shimmed for 30%. Alot of racers also use a P3 ( hot ) glow plug.
Go for the 25% on the medium plug ???????????
How different will I find the tune, power, temps, ease of tune ???????????
Big Lee is offline
Old 05-26-2009, 10:52 AM
  #24
afm
afm's Avatar
Yes more nitro not only advances timeing but incremets compression, so you must compensate with increasing your deck height and maybe move to a colder plug.
To much retarded ignition will reduce overall power noticeable.
AFM
afm is offline
Old 05-26-2009, 11:02 AM
  #25
afm
afm's Avatar
Yes, off road engines work well and safely at 25% nitro, but since moving to a higher nitro will increment compression, I would go to a 99T plug, to compensate for the extra heat. You will find the extra low end punch you were lacking. You will have to retune your carb.
As per your method of carb tuning, I desagree with leaning to much the LSN. I work the opposite, rich but not bogging LSN, and lean appropiately the HSN.
AFM
afm is offline
