Old 05-06-2009, 09:25 AM   #1
Default car not starting
hi i have recently broke the pullstart on my old cen and we have tried to use a drill but it is not working, the engine heats up and smoke is viewable from the exhaust but it is not firing up
hypergpx4 is offline   Reply With Quote
Old 05-06-2009, 09:40 AM   #2
If your engine is not starting, then that's not smoke you're seeing from exhaust but more likely excess unburnt fuel.
Check your glowplug and glowplug ignitor. The plug may be dead or GP ignitor may need to be recharged. If both are new and freshly charged, then its time to adjust your carb needles. They might be set too rich, causing the engine to flood.
Check your manual for factory settings and work your way from there, which is usually good settings for getting engines started then tune (adjust) engine from there.
Hope this helps
Kyo83 is offline   Reply With Quote
Old 05-06-2009, 09:50 AM   #3
thank you
new ofna DM1 pics and thoughts :):) dremelboy Nitro On-Road 1562 11-01-2015 06:44 PM
Atria Car Park Speedway tIANcI Malaysian R/C Racers 26519 12-07-2013 06:04 PM
YOKOMO MR4-BX stegger Electric Off-Road 592 05-04-2012 10:10 AM
Jammin' X2 Buggy NsideLine Nitro Off-Road 479 09-02-2010 10:36 AM
Ask Mike Blackstock Mike Blackstock Electric On-Road 909 10-02-2005 09:23 AM
ASEAN CUP 1/10 nitro bulldog1 Malaysian R/C Racers 93 03-22-2004 12:06 AM
SEO by vBSEO 3.5.0
