Serpent 960 use Kyosho rims? >
Old 05-01-2009, 08:15 PM
Default Serpent 960 use Kyosho rims?
I have a first version of 960, should I use Kyosho rim or Serpent rim?
ioxqq is offline
Old 05-01-2009, 08:33 PM
Serpent-Dan's Avatar
Trader Rating: 18 (100%+)
You can use the kyosho or mugen rims if you have the offset 2 parts but the only reason that they are using the kyosho or mugen rims is to really have one set of rims to use and not to go looking for either or. If you have access to serpent rims then no need to switch. Hope this helps its really choice.
Serpent-Dan is offline
Old 05-01-2009, 08:43 PM
Thank you for your help. What is offset 2 parts? Does it comes with Serpent 960 first version?
ioxqq is offline
Old 05-01-2009, 09:22 PM
Pattojnr's Avatar
Trader Rating: 19 (100%+)
no, the only serpent it comes std with is the 960 08 kit onwards. on the setup sheets it is OS2 that will be ticked when used.
Pattojnr is offline
