Old 12-09-2003, 08:31 AM   #1
Default Best Servos for a HPI N RS43 SS Kit?
what is everyone running/recommend for the following:
Steering servo?
Throttle servo?
I have my kit on the way..and I am trying to get the needed parts on order so I can start to build right when it arrives!
Thank you
UNITED_RC is offline   Reply With Quote
Old 12-09-2003, 10:11 AM   #2
KMac's Avatar
Any standard servo (Futaba s3003, etc...) will suffice for the throttle.
I'd get a digital servo for the steering. You can save some coins and get a Hitec 5645 digital or spend more and get a Futaba, etc.....
Here's a nickel's worth of free advice. Throw away the HPI steering servo saver and replace it with a Kimbrough. You'll thank me later.
KMac is offline   Reply With Quote
Old 12-09-2003, 10:13 AM   #3
so the throttle does not need to be a high-speed servo....BUT the steering servo should be a high-torque servo?
Old 12-09-2003, 11:02 PM   #4
Smoke21's Avatar
Location: Pacifica, California OR Clearlake Oaks, California
Send a message via AIM to Smoke21
depends if you are going Hi proformance I donno but if just bashing I have an Airtronics MX-3 with 2 Airtronics 94102 Servos(standard w/ the MX-3) works fine in my Type SS
Smoke21 is offline   Reply With Quote
Old 12-10-2003, 02:57 AM   #5
Fisher890's Avatar
I Bought an Mx3 Air as well but went with the Hi Tec 625MG servos Z plug for airtronics. They seem to have the torque to do the job and the speed as well for the $.They Run in the $40 range each and the metal gears (MG) Help through the early break in periods of getting it right.The basic things in setting up your servos to work right are to make sure that when on your Steering You Go Full Right or left that your servo doesn't stop before you are all the way turned and that both Right and left are adj. equally. You need to retard your steering accordingly by means of your Steering endpoint adj. on your Radio transmitter for that.Same with the Throttle But you probably already Know this.Budgetwise Any Bottomend Nylon drive ,speed for $ Hitec 625MG ,Hi end coreless and digital Money To Burn 1:1 Forget the servos.....
Fisher890 is offline   Reply With Quote
hpi rs4 3 18ss PLUS or hpi rs43 DRIFT? vinsedprince Nitro On-Road 0 02-18-2008 08:57 AM
hpi rs43 evo w/tons of ups driftah R/C Items: For Sale/Trade 0 12-04-2007 08:53 PM
HPI RS43 roller Hugh R/C Items: For Sale/Trade 27 01-14-2007 07:19 PM
Nitro Rs43 Type Ss F/s Jbell R/C Items: For Sale/Trade 16 02-11-2003 10:44 AM
rs43 2 speed wahturi Nitro On-Road 7 01-01-2003 11:28 AM
SEO by vBSEO 3.5.0
