Old 04-09-2009, 11:16 AM   #1
Default Idle needle/start up
Needed some help frp, you guys. Lately I've had problems starting my car. It'll turn over but not stay running. Feels like the idel needle is too rich. so I lean it out and start it. Runs w/o problems. But after running couple of laps, the engine warms up and dosen't want to idle back down so it revs high and wants to keep moving. So I lean out the idle screw and problem solved. Only thing when I go back to starting it up again a few days later, I have the same problem all over again with it flooding out the engine and being too rich at startup.
Any sggestions?
dvu is offline   Reply With Quote
Old 04-09-2009, 04:19 PM   #2
Trader Rating: 15 (100%+)
I'd go through the following troubleshooting steps:
1 - Make sure your HSN is tuned well. There's a chance you're way lean on your HSN but that your overall engine temps appear OK because you're way rich on your LSN.
I'd get the car started (doing whatever the heck you have to do with idle screw and low speed needles) and run the car around at racing speeds for at least three minutes. Then start doing some high speed passes. *Richen* the HSN an hour at a time until you actually see (and more importantly hear) a fall-off in speed. Once you hear this fall-off lean it one hour. I'm guessing/hoping that what you'll find is that your HSN is too lean.
The only challenge in this step is that if you leave the car sitting long at all, it might load up and then when you do your high speed passes it may act rich at high speeds simply because there's residual fuel. For this reason one you start doing your high speed passes, try not to let the car sit much at all. And since it'll sit for a minute while you make your one-hour changes to the HSN, don't "count" the very next high speed pass. Rather do a few so you're confident there's no residual fuel.
2 - Because the theory I'm operating on is that your LSN is too rich, your next step is going to turn the idle screw counter-clockwise a bit so that the gap is even smaller and then compensate by leaning the LSN a bit. This will take some experimentation but when you get it right, the acceleration should be good and you shouldn't have the symptom where it high-idles and then drops down after 5 or 10 seconds. It's very common for the idle gap to be too large but the LSN is tuned rich enough to make the idle sound OK.
If I'm suggesting you do exactly what you've already tried then I apologize!
Arboleda is offline   Reply With Quote
Old 04-09-2009, 09:34 PM   #3
I appreciate the help. I guess it's just going to take time and a lot of patience.
Houstons Engine Service H.E.S. houston Offroad Nitro Engine Forum 8786 09-26-2016 05:40 PM
JP engines jasoncsc Onroad Nitro Engine Zone 1156 04-29-2015 08:06 AM
Ask Aaron Waldron Aaron Waldron Nitro Off-Road 4285 11-03-2011 12:23 PM
Team TTC GT-4 Singapore R/C Racers 7281 12-24-2010 08:45 AM
Tuning Class..any SIFU (klang valley) offer engine tuning class??.. azmin Malaysian R/C Racers 17 06-20-2008 09:42 PM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
SEO by vBSEO 3.5.0
