Old 12-01-2003, 09:07 PM   #1
Default Crank bearing size for NS12
Does anyone happen to know what size the bearings are for the NS12 and the main advantage of the larger crank diameter?
mrckymrk is offline   Reply With Quote
Old 12-01-2003, 09:11 PM   #2
InitialD's Avatar
Default Re: Crank bearing size for NS12
Front bearing size is 7x17x5 with more balls than the previous version for better guidance of the crankshaft. The only thing I can think of having a larger crank diameter is reliability not forgetting increased rigidity whilst reducing unwanted vibrations.
Old 12-02-2003, 01:22 AM   #3
ziggy12345's Avatar
The larger crank is needed for the extra power. The rear of the crank is not supported so the force from the piston deflects the crank downwards on the ignition cycle resulting in loss of power. A larger diameter crank reduces this.
Another way is to have the crank made from a stiffer material, Titanium
ziggy12345 is offline   Reply With Quote
Old 12-18-2004, 01:05 AM   #4
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
a titanium crank will work good for a little while, but it does expande with heat. I've seen them run in an OS engine and the TI crank expanded and seized in the bearings. However, it does work very well with a nitro drag car beacuse the engine isn't running for that long at the 250+deg mark
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
8T cb bearing size ericspainter Nitro Off-Road 7 09-09-2007 08:55 AM
540motor bearing size? agp Electric On-Road 1 03-25-2007 08:39 PM
What thread size is on the SG crank? no4hitter Onroad Nitro Engine Zone 2 09-24-2004 03:05 PM
motor bearing size 403forbidden Rookie Zone 3 09-11-2004 11:50 PM
Need Thrust bearing size for TC3 bigoTC3fan Electric On-Road 0 08-02-2004 08:34 PM
SEO by vBSEO 3.5.0
