!!HELP!! Engine Advise MX 12 MAX3 MF
Hi all,
I am new with all this so bare with me. I recently came across several RC NITRO cars. One came with this engine: MX 12 MAX3 MF Tuned by Massimo Fantini. I know nothing about this engine. The problem i am having is that its hard to start and once runninng it will die within 2-3 mins. I have taken pics of this engine and would like some advise on how to keep it running and what i need to do to tune. I have attached some pics so u can see what i am working with. many thanks. I have added some RED LINES that look like they are screws to adjust. please if you can let me know what screw to turn and how many times. I am LOST PLEASE PLEASE HELP
Mentat
Mentat
The horizontal line is the idle speed screw or air gap. The left vertical line is the cinch bolt that holds the carb in place (not an adjustment) The middle line is the seat of the idle mixture adjustment. Its turned farther out than usual. But maybe that works for that engine. The right one is the main fuel metering needle, usually called the high speed needle. If your trying to get it to idle for 3 minutes? Try turning in the idle mixture adj. (middle line) One quarter of a turn (clockwise)
When starting this engine it appears that it can be started either clockwise and counter clockwise, which way should the engine run? counter or clockwise?
