Old 03-28-2009, 08:58 PM   #1
Default Nitro rs4 RTR 3 evo+ HELP!!!
Hi, i have a Nitro rs4 and one of the my pinion gear is stripped. How do you remove the pinion gear off the clutch bell? I've tried heating it up and couldn't get a chance to get a grip on that thing due to the heat. I couldn't manage to come up with a way to get a grip on the clutch bell without damaging the clutch bell and the second gear or burning myself. any help would be appreciated
Monsterous is offline   Reply With Quote
Old 03-30-2009, 08:54 PM   #2
hey bro im not positive but i think that clutch bell is one piece. The spur gears r pressed on to it, i will take a look at my friends tomorrow and let u know
Capricorn LAB C-01 / RBtj 10 / Spectrum DX3
Roadrash730 is offline   Reply With Quote
Old 03-31-2009, 09:12 AM   #3
on the rs4 3 both pinion gears are threaded onto the clutchbell. the only thing i can suggest is brute force. on mine i just heated it up, wrapped paper towels around the bell and grabbed the gear with pliers and just hulked it loose. hope that helps.
gladcow is offline   Reply With Quote
Old 04-01-2009, 04:51 AM   #4
beers4evo's Avatar
hey the way i got my pinions off is heat is up, dosed it in some flammable liquid (forgot which one) and then got the pinion pliers and loosened them...they are really tight at first so have some patience
Kyosho RRR Evo2 WC / O.S Engines / Twister Tyres / Futaba / Sanwa / Tornado
- im taking you down, im taking you to funky town!
beers4evo is offline   Reply With Quote
Old 04-11-2009, 09:24 AM   #5
codeofdastreets's Avatar
Send a message via AIM to codeofdastreets
grab second gear wit a baby channel lock nd use a vice grip or another channel lock to unscrew 1st gear. If u can grab the clutch bell wit the vice grips dat would be better. grab the clutch bell rite next to the 2nd gear since the metal is strongest there
yokomo gt-4 4/s give me a offer
mt nitro roller 4/s - 80-200 depending on wat u want on it
rs4 2 parts 4/s tell me wat you want
codeofdastreets is offline   Reply With Quote
SEO by vBSEO 3.5.0
