Kyosho Evolva
#436
I think doing the whole drivetrain with ceramic bearings might be a little overkill, but today I took my Max engine to the track after change of conrod and to ceramic bearings for both crankshaft bearings and that engine just went "zip zip". I'd say ceramic engine bearings are good investment.
#437
I am selling an extra kit that I had bought as a spares kit. I now have enough spares not to need this kit anymore. The box is still unopened. See it on eBay at http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5905267778
I hope I am not breaking any rules here
#440
Originally posted by BIBOY
yup went to boca website and they have alot ther i just need to measure all my bearings...
Shaft bearings.....BRG025......6 x 13 x 5mm........x4
2-speed bearings..BRG006....6 x 12 x 4mm........ x2
Clutch bearings.....BRG001.....5 x 10 x 4mm........x2
The only bearings missing from this lot are the thrust bearings and the steering and brake bearings.
Incidentally, these bearings are the same size as the MRX3 except for the 2-speed bearings
#441
Re: set up sheet?
does anyone have a set up sheet for the evolva? or web site that i can download one? thanks guys!!
http://www.kyosho.co.jp/instructionm...3_evolva_t.pdf
Parts listing is at
http://www.kyosho.co.jp/instructionm...3_evolva_p.pdf
Manual is at
http://www.kyosho.co.jp/instructionm...3_evolva_m.pdf
#442
shock of evolva
i guess most of you guys out there are quite experince with seting up the car. just a question, does this evolva torque steer when you full throttle from stationary stop? is it that the stock suspension is too soft ?
#443
Originally posted by dougday
Wheel Bearings....BRG018....12 x 21 x 5mm.......x12
#444
Re: Re: set up sheet?
Exploded view is at...
Parts listing is at
Manual is at
Parts listing is at
Manual is at
#445
Ceramic bearings are the way to go, if you dont mind lightening your wallet a few hundie$$$$
#446
#447
Originally posted by C Verano
No thanks.
No thanks.
#448
I know what you mean Good luck at the O'donnel race Chris!!!I'm going to try to sneak into the A-Main!!!!
Thanks...Good luck to you too. The race should be pretty good with Barry Baker, Darin, Josh, and all the other Rev locals there racing 1/8th scale.
#449
