Kyosho Evolva
#1591
The kit comes with a 7-2 in (7 high 2mm in towards center) rear aluminum hinge pin block. An optional 7-0 is offered by Kyosho (not included in the kit). Although there are only 2 offered positions for the bottom hinge pin, the top camber link also has 4 different length/angle adjustments that alters the roll-center add the multiple size spacers you can add or subtract. So the answer is yes you can change the roll-center of the evolva.
Hi snake-eye
Please can you clarify where to out the shims and what effect it will have - e.g. 2mm above will increase rc.
Acid
#1592
You put extra shims under the upper arm outer end pivot ball (the kit default is one of the blue 3mm spacers) adding 2mm gives you an increase in roll center of just over 1mm, also because you've altered the angle on the upper arm the camber gain pattern has been altered.
#1595
#1596
KYOSHO EVOLVA
You can pick up the plastic screws for the body adjustments at any electrical house. Fryes has a great selection.
I bought four or five packages there <many sizes> and also the plastic screws for the body side braces there also. Lots of drivers pop rivet the side body supports on, but I use the small plastic screws, as they can be removed as needed.
#1598
Thanks Rick, appreciate it
Regards
Acid
#1599
Rick, your notes are correct. Those are the correct part numbers but on the Kyosho America website, go to shop Kyosho and do a search for the FM 377. It comes up as a Evolva front belt.
Question, why will Kyosho make and sell it if it doesn't work
Acid
#1600
Overdrive
Hi Guys
I am trying to figure out what is the amount of teeth on the rear pully - the big pulley that sits on the rear wheel shaft.
Trying to work out my overdrive...
Acid
Acid
#1601
Read post 1544 replying to your question in post 1543
#1603
The part number you need is FMW40 Spoiler Screw Set(1/8 Racing/M6/2Set).
#1605
