Shepherd Velox V10 >
Shepherd Velox V10
Shepherd Velox V10
Old 12-15-2014, 07:33 AM
  #1426
QuiXoTic_NL's Avatar
Looks like the Shepherd 2015 contender is available: https://www.facebook.com/permalink.p...d=210352703968
QuiXoTic_NL is offline
Old 02-18-2015, 02:08 AM
  #1427
Hows everyone going with this car?
CameronMADOG is offline
Old 02-18-2015, 01:49 PM
  #1428
Trader Rating: 15 (94%+)
Hi Cameron so far the Velox v10 has been pretty impressive.
I got one of the last 2014 spec kits which came with the new 2015 team edition chassis. i have updated some of my parts to new the 2015 spec including the lightweight 2 speed shaft and the updated ackerman plate which really transformed the car giving it more steering and better stability.
Setup wise its pretty close to stock except for heavier diff oils, 300k front and 100k rear. black springs which are super soft compared to the kits soft. 2.2 instead of the 2.3 stock front sway bar. after 4 race meets and about 2 practice sessions i am still using the original spurs and pinions and i cant see any wear in the shafts so quality looks good.
Maintenance on this car is easy with just 4 screws to easily remove diffs. the wheel axles can be easily removed by removing a big snap ring. the tank comes out by removing 2 body clips so you can easily clean underneath.
some recommendations:
- brass battery tray. this car is light! i use a low profile throttle servo and full size steering servo with life battery and my car weighs 1640 on blank rims so i have also added thebrass tray an additional 10g weight for balancing.
- aluminium diff pins will save you an extra 10 gram off the driveline
- shorter gear ratio. the kit pinions are a bit tall for our aussie tracks.
mrgsr is offline
Old 02-18-2015, 01:50 PM
  #1429
Next club day we will have our 4th velox v10 racer so the car is starting to get popular here in sydney
mrgsr is offline
Old 02-19-2015, 12:54 AM
  #1430
I'm building mine:
Old 02-19-2015, 02:24 AM
  #1431
Excellent car. Like all Shepherd cars this one works best with heavy diff oils. 80 to 100k rear and 200 to 30th front. Went through all possible diff oil combinations and I am now using 100k rear and 300k front. Installed all possible option part and had to add on weight. So brass tray is compulsory especially if you use low profile servos.
buzz777 is offline
Old 02-19-2015, 02:43 AM
  #1432
Michael_T's Avatar
Trader Rating: 52 (100%+)
I love my V10!
Michael_T is offline
Old 02-19-2015, 12:09 PM
  #1433
Robert_K's Avatar
I'm ready:
Regards Robert
Robert_K is offline
Old 03-03-2015, 12:57 AM
  #1434
Should have my car kits tomorrow, looking forward to it, and looking forward to getting some decent results might have to change my sig picture now lol
Old 03-05-2015, 02:12 AM
  #1435
Build going well, replaced all screws with lightweight arrowmax
Old 03-05-2015, 03:31 PM
  #1436
Michael_T's Avatar
Looking good Cameron, nice screw kits, where did you get them from?
Make sure to follow the attached document when changing the shock rebound...
Old 03-08-2015, 04:31 AM
  #1437
bought them from speedyrc in brisbane, The car kit has been great so far, one of the best kits i have put together,
Old 03-08-2015, 06:46 AM
  #1438
very nice cars...
Ehmc2014 is offline
Old 07-19-2015, 10:10 PM
  #1439
Michael_T's Avatar
The Shepherd Velox V10 continues it's strong showing, winning this weekends round of the ENS...
Old 07-20-2015, 06:34 PM
  #1440
Originally Posted by QuiXoTic_NL
I'm building mine:
How many teeth are on those pulleys?
Do you think they will fit XRAY cars?
I believe the 2 outside pulleys on the nt1 are 25-19 and the inside pulleys are 18-19. Has anyone switched to this car from xray? WHat are your thoughts and comparisons between the 2?
Really like the design of this car, but very little support in my area
JOE SI is offline
