Shepherd Velox V10
#1411
Dear Christoph,
unfortunately I can't say anything about the release date yet, but for sure it will be way in time for the next season.
Best regards
Patrick
Best regards
Patrick
#1412
Hi!
I'm still drivin older V10 with some updates
Two movies from last race.
https://www.youtube.com/watch?v=-s5K...lnWLrB_zFhTWtg
https://www.youtube.com/watch?v=Ujz6...lnWLrB_zFhTWtg
But I lost my big luck with plug at 11 min ;-), anyway, 15 sec laps.
I'm also waiting for something new in 2015
Regards
michal
Regards
michal
#1414
Hi!
Regards
michal
Regards
michal
Great movies ! Your car is stable and runs well.
Good to see V10 drivers from around the world.
Shame about the plug though ...
Greetz,
Christoph
#1417
Quick question.......does the rear portion of the top deck float??? Like the Xray 2013.
#1419
Those that come with the kit are fixed inserts (no flex).
Maybe those can be replaced by other inserts which provide flex.
See page 30 in the manual here : http://www.team-shepherd.com/pdf/V10...ANUAL_2014.pdf
Greetings,
Christoph
#1420
Hi!
Newbie question.
How to prepare tires for 45min main ?
I'm going to put at rear 45 on R side (it goes faster) max diameter posible,
L side 42 tire maybe 1mm less then R side.
Fronts 42 R side, 40 L side, same diameter, 2-2.2mm split from L rear side.
I don't know if my plan will be OK but for that track where will be my last nitro racing this year I remember, that R side goes faster ...
Any tip from experienced driver will help me and my friends
Regards!
m
Newbie question.
Regards!
m
#1421
Hi!
Newbie question.
Regards!
m
Newbie question.
Regards!
m
I would'nt know since i only drove for a small while 1/10 IC couple of years back. I always used 40-42 or 37-40.
Greetz,
Christoph
#1423
What.
#1424
What a car !
The Sunday that just passed i ran the new Velox Pro 2014 Spec with the new pro spec chassis and i have to say this car is awesome!
Our local track had not been run on for a few weeks and with recent showers the traction was very low. Off throttle understeer and on power over steer was making the car a bit hard to drive.
I changed the front shock piston from 2 hole to 3 hole and with a softer rear arb the car was dialed in. I did have to pull the trigger slowly getting on the power because the clutch was just insane! after 3 rounds of qualifying i qualified 4th.
I finished the 30 min main final in 2nd place after losing a bit of time at the start trying to keep out of trouble .
Looking forward to the next time out ! will post my setup soon
