Old 05-04-2014, 04:28 AM   #1396
To The Top!
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 05-05-2014, 10:52 AM   #1397
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
U mean to tell me nobody has said a word about this car for 6mos!!
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 05-06-2014, 01:47 AM   #1398
Perfect car doesn't need any word :P
Michal Abramowicz
Old 07-30-2014, 03:55 PM   #1399
hi!
I'm looking for info what is proper way to do ride height.
For example, front tires 61, rear 63.
Front RH = 6
What RH should be at rear end?
6? 7? 8?
Front down stop = 0
Rear down stop = 3 or 4 it depend (3 on bumpy track).
Thanks in advance
Michal Abramowicz
Old 07-30-2014, 04:40 PM   #1400
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Originally Posted by M.Abramowicz View Post
hi!
Front RH = 6
6? 7? 8?
Front down stop = 0
Thanks in advance
Set ride height on blank rims. I set mine 1.0mm front, and 1.5mm rear.
Just check your chassis. If you find one end is not as scratched from hitting the ground, you can probably go lower on that end. Some tracks you run even front/rear heights, other tracks you may have to run higher rear.
Shepherd RC | Brilliant RC | Arrowmax | Xtreme Aerodynamics | Matrix | Tectrade TTB
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 08-23-2014, 03:06 PM   #1401
Thanks for replay.
It is std advice for 1st step? Just asking, no offence.
It looks like RH depend then on foam on tires (normal for me).
What diameter of foams then you start?
In my case I set (compute for blank 50mm rims) I did usually 1.5mm front, 2.0-2.5 rear. Maybe this is wrong ... for me because last time I lowered 1mm overall RH on my car (60/62.3) tires and car was slighty better
Just need to compare some infos in my head.
Michal Abramowicz
Old 09-02-2014, 03:36 AM   #1402
Send a message via ICQ to CivicTuning
Is there a new version coming ? 2015 ?
On the Shepherd USA site it says :
2 items in stock
Warning: Last items in stock!
Greetz,
Christoph
Capricorn LAB-C801
RB CX-R
Futaba 4PK
CivicTuning is offline   Reply With Quote
Old 09-02-2014, 03:52 PM   #1403
shiston's Avatar
I don't think so, the V10 Pro was released not too long ago this year.
Hang around......we'll talk some more
shiston is offline   Reply With Quote
Old 09-03-2014, 02:03 AM   #1404
Thanks Shiston.
Well, you never know, since Capricorn has the C802 coming and their C02 will be updated too, Mugen is busy too now with the new MRX-6 i heard ...
Greetz,
Christoph
Capricorn LAB-C801
RB CX-R
Futaba 4PK
Old 09-03-2014, 11:56 AM   #1405
QuiXoTic_NL's Avatar
Actually the V10 Pro was released in 2013 and is also available als a 2014-version with some very minor changes. Since the release of the original V10, there has been a new version with some changes every year, where the introduction of the V10 Pro was by far the biggest change. When you look at the setup-sheets in the download section Team Shepherd Downloads you can find the setup of Patrick Shaefer that he used for the 2014 Euros. On that setup sheet it has been noted that he was running a new servo saver prototype and a new chassis plate prototype. I would not be surprised if there was going to be a 2015 edition (or a world championship edition should they win the world championship this year).
The reason I have investigated in detail is that I am considering a move from the Serpent 733 to the V10 Pro. So I would certainly be interested in information from a reliable source.
Shepherd V10 Pro 2015 - Matrix tires - Novarossi Engines - Runnertime
QuiXoTic_NL is offline   Reply With Quote
Old 09-03-2014, 03:35 PM   #1406
I also have 2 733's somewhere in the attic, lol.
I am interested as well in driving the V10 in 2015 ...
Any reliable source here to confirm a new car is coming ?
Greetz,
Christoph
Capricorn LAB-C801
RB CX-R
Futaba 4PK
Old 09-03-2014, 03:58 PM   #1407
shiston's Avatar
Maybe best to just email Patrick through the Shepherd site
Old 09-03-2014, 11:35 PM   #1408
Hey guys,
nice to see that you are interested in the Velox V10.
Indeed I used a new servo saver prototype part and a chassis plate from a different material which both worked very good in Valencia. We have already put them into production and they will be available soon.
For the 2015 version these two items will make it into the kit, probably the light weight gear shaft as well.
Other big changes are not planned at the moment as the current version works really good (maybe we update some minor parts).
Best regards
Patrick
www.team-shepherd.com - www.sonic-engines.com
Trick is offline   Reply With Quote
Old 09-04-2014, 12:24 AM   #1409
Hi Patrick,
Very cool to see you are so open about the development of the product. That is not so common, thanks! I usually buy two kits at once (to have a spare part for everything) but in this case I might consider getting a single 2014 kit so that I can race it in the last one or two races of this season and then get a 2015 when it becomes available, without risking incompatibility of the parts. That way I would already be familiar with the platform when the 2015 season starts.
Old 09-04-2014, 01:47 AM   #1410
Originally Posted by Trick View Post
Hey guys,
Best regards
Patrick
Hi Patrick,
Great to see you are so open indeed !
This makes it only easier for us to choose the Velox V10.
Now the question is, when will the new kit be available ?
Greetz,
Christoph
Capricorn LAB-C801
RB CX-R
Futaba 4PK
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Sheperd Velox moy Nitro On-Road 585 04-19-2012 09:51 AM
Serpent 733 vs. Shepherd Velox V10 Geberit Nitro On-Road 27 07-06-2009 04:28 PM
Upgrade/ RCiD ryno1922 Nitro On-Road 26 03-31-2009 01:49 PM
Shepherd Velox V10 macaurc Nitro On-Road 31 03-02-2009 08:35 AM
