Old 02-23-2013, 08:32 AM   #1306
G87z's Avatar
Originally Posted by emankov View Post
Need opinions for our latest velox mod
Not tested on track yet but...very soon
Attachment 1034721
My suggestion would be to go away from the upper arm/camber link setup and use a normal camber link like the Xray and other chassis. We have been cutting the upper arms in this fashion for sometime now. Allows the rear suspension to move more freely and react better.
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 02-23-2013, 08:34 AM   #1307
G87z's Avatar
Originally Posted by stefan View Post
Why not just use a camber link?
That's what I understand the next V10 will have....
Stefan. SHHHHHHHHHHHHHHHHHHHHHHHHHHH LOL
Old 02-24-2013, 09:19 AM   #1308
GREGORY!'s Avatar
Do you see a more forgiving rear end? ?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 02-27-2013, 03:04 AM   #1309
Hi!
Anyone can show pictures of installed RX without receiver case?
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 03-04-2013, 07:49 AM   #1310
Default whats going on
it is to quite hear. lets here from the RAM
bigtee is offline   Reply With Quote
Old 03-04-2013, 08:11 AM   #1311
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by crafty63 View Post
Has anyone tried the EC 2012 chassis update? With the ball bearing rear roll bar? Any comments on performance compared to the original v10?
I have it on my car and it provides more flex giving more mechanical grip. If you race on low grip tracks it improves the performance compared to the older style. For high grip tracks you will need to use the chassis brace, either the carbon one or use a tie-rod, or the original chassis brace because the flex makes the car grip the track like it has teeth.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 03-05-2013, 07:13 AM   #1312
Hi!
I'm trying do my wires ...
Also must find life pack for that car ...
Think about vapex http://www.vapex-racing.com/goods.php?id=102
LF93572--6.6V/1000mAh, what do you think?
Shepherd Velox V10-img_20130305_131136.jpg   Shepherd Velox V10-img_20130305_131211.jpg   Shepherd Velox V10-img_20130305_133241.jpg
Michal Abramowicz
Old 03-05-2013, 09:58 AM   #1313
YmeBP's Avatar
Originally Posted by M.Abramowicz View Post
Hi!
4 cell nimh weighs (good nimhs i should say) only slightly more than what you have and are a little less fickle than life while providing similar performance and voltage.
Also i'd suggest you put those wires on the other side of your receiver (near your fuel tank, use less zip ties and make sure they don't rub the tank or chassis) and run the plugs up near the roll over bar. You can even glue the socket to the roll over bar. It will clean that area of the car up. I'd also suggest taking a little cleaning putty and putting it in the bind plug hole of your receiver and around the servo plugs to prevent fuel in your receiver. Lastly i'd also suggest taking some rtv or rubber cement and putting a light bead around the seam where your two half of the plastic case meets.
While i love sanwa i've had issues when fuel gets into them. I use a box now and the new 471 receiver so I may go back to the open type and see what happens.
Old 03-05-2013, 10:21 AM   #1314
thanks for tips
can you post pictures of your car and focus on electronics?
i left on table 4 hours... and still not happy with result...
Michal Abramowicz
Old 03-05-2013, 10:43 AM   #1315
YmeBP's Avatar
thanks for tips
Will do i can show you mine w/ the box. I'll dig around and see if my other chassis have electronics on them.
I attached some photos i don't have any cars w/o a box =D.
Old 03-05-2013, 10:53 AM   #1316
Default what happening Tory
Tony from Baltimore. whats has change on the v10 or what have you and Gmac done to make the car better i have been thinking of buying the chassis ec kit but $250.00 is a bit much for just a new chassis and top deck and a few parts. Gmac said that in April the are coming out with a new car if so what are the changes?
Old 03-05-2013, 12:09 PM   #1317
YmeBP's Avatar
Great to hear from you man!! Can't wait to hit the tracks this summer hahah.
First part What did I change:
1) I am using an aluminum chassis brace with the same kit/setup you have. I find that i prefer my car stiffer in the chassis and then i tune w/ suspension changes ie shock oil and springs etc. I'm not a high enough skilled driver to leverage the flex consistently. However i've seen it put to good use and it works and works REALLY well.
2) Gmac ran the EC setup so I'll let him answer those questions, I found that watching his car he was super flat. He was able to tune his car a bit easier than i was able to tune mine. Meaning he seemed to be a little better balanced. Where i ran soft he was able to go a little harder and get more rotation in the corners. I can also tell you that I finished middle of the pack at the winternats w/ basically the same car you have (had some traction roll issues because i cut my tires too tall when the times for the mains were changed). To me that speaks volumes considering the level of competition that was on hand. Gmac was a bit quicker than me so you may want to take a look at the upgrade hahaha.
3) I can't answer that one for you, i can tell you that i'll be in germany in a couple weeks and we are planning to stop by the factory and i'll post whatever pictures i'm allowed to take =D. Shepherd USA has the EC kit in stock and will have the new kit shortly after release so you will be able to make an informed choice.
Depending on what's available and if my wife will let me build it hahaha I may be running the new kit at Fiorano in early April.
Old 03-05-2013, 12:32 PM   #1318
gearhead_22's Avatar
Send a message via AIM to gearhead_22
theres to much crap on that car.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is online now   Reply With Quote
Old 03-05-2013, 12:38 PM   #1319
YmeBP's Avatar
Don't worry, it will be in front of you w/ all it's crap
Old 03-05-2013, 01:30 PM   #1320
thanks Tory for the info. i can't wait to hit the track myself been going through withdrawals all winter is it April yet? see you at the Diamond
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Sheperd Velox moy Nitro On-Road 585 04-19-2012 09:51 AM
Serpent 733 vs. Shepherd Velox V10 Geberit Nitro On-Road 27 07-06-2009 04:28 PM
Upgrade/ RCiD ryno1922 Nitro On-Road 26 03-31-2009 01:49 PM
Shepherd Velox V10 macaurc Nitro On-Road 31 03-02-2009 08:35 AM
