Old 01-16-2013, 01:28 PM   #1291
kewdawg's Avatar
Originally Posted by 1evo RRR Driver View Post
Can't believe he went back!!
why??? Top drivers bounce around. Nothing new.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 01-21-2013, 06:50 AM   #1292
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Some practice on small technical track (very bumpy) from Chile - Southamerica : http://youtu.be/-sOMoD9sSsY
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 01-21-2013, 12:55 PM   #1293
JamesHealey's Avatar
Is it just the sound recording or is your engine lean bogging a bit?
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
Old 01-21-2013, 01:49 PM   #1294
G87z's Avatar
If the track is super bumpy like they described the car may be coming off the ground in sections allowing the engine to rev up for a split second.
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 01-21-2013, 02:21 PM   #1295
Tabushi's Avatar
You are right. No lean bog just bumpy track ... will try to minimize that ...
Old 01-21-2013, 11:57 PM   #1296
kewdawg's Avatar
Try 3 -hole piston with 400 CST oil and the soft spring (white / grayish color). Should help a lot.
Quinn Moon
Old 02-21-2013, 07:10 AM   #1297
emankov's Avatar
Need opinions for our latest velox mod
Not tested on track yet but...very soon
emankov is offline   Reply With Quote
Old 02-21-2013, 09:39 PM   #1298
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Attachment 1034721
Why u didn't just make it a T shape, would cutdown on material/weight......just a thought N it looks like u can't put enough camber in that....
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 02-21-2013, 11:43 PM   #1299
stefan's Avatar
Send a message via AIM to stefan
Attachment 1034721
Why not just use a camber link?
That's what I understand the next V10 will have....
stefan is offline   Reply With Quote
Old 02-21-2013, 11:52 PM   #1300
Or you could have cut the aluminum to about the diameter of a body post and use plastic bushings front n rear to center the link......
Old 02-22-2013, 12:11 AM   #1301
Here's a pic of what I was trying to say........ 2 options that I think would save weight n look neat
Old 02-22-2013, 12:21 AM   #1302
More detail!
Old 02-22-2013, 07:08 AM   #1303
stefan's Avatar
Just do it like that. The pillow ball (the one from the sway bar) rides on the original upper arm pin and is secured with the grub screw
Old 02-22-2013, 07:25 AM   #1304
Perfect!!
Old 02-22-2013, 07:31 AM   #1305
emankov's Avatar
We thought of all those ideas,and all are good, but all we want to achieve here is a good stability of the low
wishbones (especially during highspeed turns) minimum flexibility and good durability of the whole rear system.
The camber can be set as far as -+ 3.5 degrees which is enough
The weight of each upper wishbone is 1.5 grams heavier than the stock and yes we can reduce this more.
This is for a test we want to do this Sunday but weather is bad so we have to wait
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Sheperd Velox moy Nitro On-Road 585 04-19-2012 09:51 AM
Serpent 733 vs. Shepherd Velox V10 Geberit Nitro On-Road 27 07-06-2009 04:28 PM
Upgrade/ RCiD ryno1922 Nitro On-Road 26 03-31-2009 01:49 PM
Shepherd Velox V10 macaurc Nitro On-Road 31 03-02-2009 08:35 AM
