Old 09-14-2011, 04:42 AM   #1111
mick8488's Avatar
Default Clutch
Originally Posted by MrHistory View Post
I finished my build and have a clutch question:
i assembled the clutch on an older Novarossi motor (m12?) from an older mugen kit. using all of the supplied washers, etc, there is a ton of end play. is the shaft on this older motor longer than a current .21 design? how long is the crankshaft on new motors?
thanks
Hi guys,
I have a similiar problem to Jason. The endplay on my clutch is way loose as well, like at least 0.5mm. I'm not sure how long I've been running it this way for but I just installed a new nova with a 11.5 crank in it and same problem. My previous engine, just prior to blowing up (cause yet to be determined) saw the clutch nut let go completely before I retightened it and I'm worried if the same might happen here because of all that endplay. Any thoughts? Is this setup still raceable?
Cheers,
Mick
NOVAROSSI WORLD s.r.l.: RACE ONE OR CHASE ONE
mick8488 is offline   Reply With Quote
Old 09-14-2011, 10:21 AM   #1112
Merrillizer's Avatar
Originally Posted by mick8488 View Post
Hi guys,
Cheers,
Mick
Put some more shims under the big clutch bearing until you have minimal endplay with no binding.
It will work with the endplay so long as your clutch gap is set right, but it will tear up your thrust bearing.
I keep a fresh can of alphabet soup in my pit bag.
Merrillizer is offline   Reply With Quote
Old 09-14-2011, 04:48 PM   #1113
G87z's Avatar
I run a shim behind the collet for the flywheel.
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 09-15-2011, 01:28 AM   #1114
mick8488's Avatar
Thanks guys,
I put three hobao 5x8 shims behind the big clutch bearing and that seemed to do it. I now only have a tick of play, and eyeballing it, it appears well within the 0.05 to 0.15 stated in the manual. Now to run in my engine....
Old 09-15-2011, 01:00 PM   #1115
quietstorm76's Avatar
Dru ygpm
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 09-15-2011, 02:25 PM   #1116
G87z's Avatar
Originally Posted by quietstorm76 View Post
Dru ygpm
Gonna switch to Shepherd? We know you see the light! lol
Old 09-17-2011, 12:20 PM   #1117
jds5150's Avatar
Originally Posted by Dru Garcia View Post
Yes! and a sweet ride it is.
This weekend was our first time out with the car and it happened to be at Homestead..
I had lots of bad luck this weekend and therefore still didn't get a chance to reaalllllly drive the car. I can tell you this though, it can withstand abuse.
I had two really bad crashes and the car sustained minor damage. And both happened after I finally got the car setup right.
The first one I was rear ended by an 8th scale at the end of the straight away into the sweeper both of us going full throttle. The 8th scale driver made a bad judgment call and hit me without braking. All that broke from the car was the shock rods in the rear (nothing happened to the shock tower or any of the aluminum.) He also made the front knuckle pop off when he pinned the car against the wall from the impact. The knuckle didn't break and nothing else broke. The 8th scale also broke...good for him!!
This was the result from the impact of an 8th scale going down a 280 foot straightaway.
Not bad!!!
Second was right before the start of my main. I was in my first warm up lap and the battery shorted out as I went into the straightaway. The car took off at full speed for the whole 280 feet into the wall. This time my wide bumper saved the car. The bumper broke and the rear upper arm, and the knuckle popped off again (the same old one I may add.) That was it.... amazing. If this doesn't prove how durable the car is, then I don't know what will.
The battery shorted out because I forced it in when I upgraded to the brass battery tray. I did this right before my race and rushed it. I paid the price for that stupid move!
I did see the front universal being an issue for a driver and I'm not sure if that is going to be addressed any time soon. I do know for sure that the front wide bumper is a must for this car.
One more thing- my main problem was the fact that the hinge pin for the rear upper arm was a very tight fit. This is not an issue for many cars, but in the V10, we use set screws to secure it as this is our roll center adjustments as well. If that hinge pin does not go in freely and the arm does not move freely after you secure the set screws, then it will not matter what adjustments you make on the car, your rear will not function right as the whole suspension is out of the game. To make matters worse, if you didn't set your camber adjustment screw center into the upper arm, then when you give yourself more camber you will force the screw into the plastic and pin the hinge pin against the plastic. That too will freeze your rear suspension. I had both of those issues. I learned a big lesson this weekend and hopefully this post will prevent some of you from going down that road.
You could try using a hinge pin reamer for the suspension arms. Alternatively, drill bit with the correct size will work too.
jds5150 is offline   Reply With Quote
Old 09-17-2011, 11:49 PM   #1118
blis's Avatar
Default Belt Tensioner Mod
We've had to add a little "magic" of ours to the V10 to resolve the floppy side belt.
Part is readily available...
http://www.rcmanufactory.com/prodimg/502266-1.jpg
Also removed the circuit from Lipo battery and installed a LiFe just in case.
h
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 09-18-2011, 04:23 PM   #1119
Trader Rating: 23 (100%+)
Default Velox V10 for sale
Interested in a great deal check this:Shepherd Velox V10
Team Associated TC7.1/HW XR10 Stock Spec/HW Bandit 10.5T/Arrowmax LP 52000 7.6v
IVAN RM is offline   Reply With Quote
Old 09-19-2011, 04:21 AM   #1120
G87z's Avatar
Attachment 809091
Attachment 809092
Attachment 809093
Attachment 809094
h
I see a few people have had the loose belt issue. I do not seem to encouter the loose belt issues that everyone else has..... I do the run the Xray side belt. Same amount of teeth. I am not sure if that some something to do with it.
Old 09-21-2011, 05:07 AM   #1121
mick8488's Avatar
Default shims
Thanks guys,
Guys, just as an FYI (but most of you probably know), don't put three 5x8 shims behind the big clutch bearing. To cut a long story short, with all those shims in there, the clutch bell could not grab the plate and engage, so the engine spun like crazy with the car going nowhere. Take it as a word of warning anyway..
Best thing to do is to leave in the amount of shims recommended by the manual or try and achieve a balance behind minimal endplay and clutch engagement. I think most V10 drivers have probably got it sorted though.
Cheers,
Old 09-21-2011, 05:13 AM   #1122
G87z's Avatar
Cheers,
Remember you have to set the Clutch Gap first by adding shims to the clutch nut bushing. Once you set the desired gap it should be pretty easy to reduce the end play by putting shims behind the big bearing. Rember when setting gap you do so without the large bearing or the shims installed. to reduce the amount of shims needed for clutch gap/end play you can place a shim behind the flywheel collet. This also makes the pinions line up perfectly with the spurs.
Old 09-27-2011, 03:40 AM   #1123
400002 is this a new version of the velox v10 eleven?
Radiopost TS401
SebO is offline   Reply With Quote
Old 09-27-2011, 05:51 AM   #1124
G87z's Avatar
Yes, but I have also seen 400001/11.
Where are you looking to purchase from?
Old 09-27-2011, 05:53 AM   #1125
The part number is 400001. That is the complete Velox V10 "11" kit.
info@teamshepherdamerica.com
ShepherdAmerica is offline   Reply With Quote
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Sheperd Velox moy Nitro On-Road 585 04-19-2012 09:51 AM
Serpent 733 vs. Shepherd Velox V10 Geberit Nitro On-Road 27 07-06-2009 04:28 PM
Upgrade/ RCiD ryno1922 Nitro On-Road 26 03-31-2009 01:49 PM
Shepherd Velox V10 macaurc Nitro On-Road 31 03-02-2009 08:35 AM
