Old 08-24-2011, 06:53 PM   #1096
Default v10 upgrade
Originally Posted by G87z View Post
The car does not need anything. You can add the Alu akerman and the Alu steering servo mount.
Oh and did you check your private messages? lol
yes i checked my pm thanks. what i am trying to figure out is what chassis do i have since i got this car used also the person that had it before me got regular universal axles in the front and the kit axles in the rear just wondering why this is that way? if i have the stock chassis where can i get the v10 11 up grade kit i didnt see it at ashford hobbies,
bigtee is offline   Reply With Quote
Old 08-24-2011, 07:27 PM   #1097
speedracer1bp's Avatar
[QUOTE=bigtee;9570063]yes i checked my pm thanks. what i am trying to figure out is what chassis do i have since i got this car used also the person that had it before me got regular universal axles in the front and the kit axles in the rear just wondering why this is that way? if i have the stock chassis where can i get the v10 11 up grade kit i didnt see it at ashford hobbies,[/QUOTE
You can try Sam at www.tma-motorsports.com
He has them in stock.
speedracer1bp is offline   Reply With Quote
Old 08-25-2011, 04:47 AM   #1098
G87z's Avatar
When you say "regular universal axles in the front" do you mean the steel ones? for the rear when you say "kit axles" what do you mean? I run the steel axles upfront because the Alu ones tend to get out of round even from the slightest touch of a board. And then you have to cut them to get the bearings off.
who did you buy the car from? Local guy or someone on here?
Like the guy above posted that shop should have the 11 upgrade in stock. Also A-Main. Ashford can order it for you from Team Shepherd America.
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 08-25-2011, 08:00 AM   #1099
the front axle are like mugens mtx4r and the rear is setup like what come in the kit
Old 08-25-2011, 08:29 AM   #1100
G87z's Avatar
That is a known conversion. people switch to the mugen knuckles,bearings,and CVD's for strength. The velox knuckles pop off the pivot ball if you clip a board with the wheel at full lock. Better than breaking. Some pople do the mugen upgrade to prevent this. Then you will break upper arms instead.
take some pictures of the car and upload them. id be interested to see what else people have done.
Old 08-25-2011, 11:33 AM   #1101
that's the only thing that i see that's different then the kit set up. would like to get the carbon fiber brace for the two speed, the 5th body post, the alloy side chassis brace and the front alloy mounts for front sway bar. where can i get them? also how does this car compare to the mtx4r? this is the car that i have now,thinking of getting the mtx5 as well. is there a wider front plastic bumper for the car or does one have to be modified to fit?
Old 08-25-2011, 12:10 PM   #1102
G87z's Avatar
Yes the Carbon brace for the 2spd is nice as is the 5th body post. It also stiffens the car a little bit in the front by connecting the 2 bulk heads. There really is no need for the alloy chassis side stiffner. you can run the car with out it as a tuning option for slight flex. The wide front bumper is also a tuning option. when used with out any foam it adds a little high speed steering. I personally run the foam bumper. The car is far superior in design compared to the MTX4r. both cars are very good. As for the MTX5 I am sure it will be a great car. My suggestion is to stick with one car and learn it inside and out. all of the new cars are very very close and it comes down to the driver.
Old 08-27-2011, 02:38 AM   #1103
well i plan on retiring the mtx4r and making the v10 my main car for now. i need to stock parts now. may not be doing much with the car the remainder of the year other then learning the car. i don't like the small bumper and i want something like the mtx4r any ideas of what will work and what should i stock most of
Old 08-27-2011, 02:10 PM   #1104
G87z's Avatar
I once too had a MTX4r. It has been retired also. I may use it for some local vintage nitro racing. There is still some good racing to be had in DE at blue diamond. we race up into October. When you say small bumper. you mean the foam one that comes with it? I use the Xray hard bumper, upper and lowe plates. some minor modification is needed to make it fit. It is about the same size as the stock one though. For parts, if you are not doing a ton of traveling to race. I would stock extra arms, Knuckles, hinge pins, turnbuckles and the ends for the turn buckles. If you are going to travel all the time. Just get a spare kit. It will have everything you need.
Old 09-01-2011, 08:17 AM   #1105
Default v10 clutch
how do you setup the vcc clutch
Old 09-01-2011, 12:07 PM   #1106
Thunderbunny's Avatar
Trader Rating: 24 (100%+)
I figured that I'd post this here first, before I post on the F/S thread. I have two V10's, batteries and spare parts. Will be asking $700 o.b.o. I'll be taking pics tomorrow. PM me if you're interested.
Chris Jones a.k.a. "Black Jesus"
O.S. l Airtronics l RSD l
Team ARC l Gulf Coast Raceway Porter,Tx
Thunderbunny is offline   Reply With Quote
Old 09-08-2011, 09:58 AM   #1107
G87z's Avatar
It is pretty quiet in here. where is everyone at?
Old 09-08-2011, 08:04 PM   #1108
Dru Garcia's Avatar
Send a message via Yahoo to Dru Garcia
We here in the beautiful sunshine state are getting ready to start our racing season.
checkout www.forgass.com for the details.
GMac- wish us luck and hope you and the gang can make a few races this year, just like last year.
Desoto Racing
www.skyrocketbatteries.com
Dru Garcia is offline   Reply With Quote
Old 09-11-2011, 02:05 PM   #1109
quietstorm76's Avatar
Dru you running Velox now?
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 09-12-2011, 07:40 AM   #1110
Dru Garcia's Avatar
Yes! and a sweet ride it is.
This weekend was our first time out with the car and it happened to be at Homestead..
I had lots of bad luck this weekend and therefore still didn't get a chance to reaalllllly drive the car. I can tell you this though, it can withstand abuse.
I had two really bad crashes and the car sustained minor damage. And both happened after I finally got the car setup right.
The first one I was rear ended by an 8th scale at the end of the straight away into the sweeper both of us going full throttle. The 8th scale driver made a bad judgment call and hit me without braking. All that broke from the car was the shock rods in the rear (nothing happened to the shock tower or any of the aluminum.) He also made the front knuckle pop off when he pinned the car against the wall from the impact. The knuckle didn't break and nothing else broke. The 8th scale also broke...good for him!!
This was the result from the impact of an 8th scale going down a 280 foot straightaway.
Not bad!!!
Second was right before the start of my main. I was in my first warm up lap and the battery shorted out as I went into the straightaway. The car took off at full speed for the whole 280 feet into the wall. This time my wide bumper saved the car. The bumper broke and the rear upper arm, and the knuckle popped off again (the same old one I may add.) That was it.... amazing. If this doesn't prove how durable the car is, then I don't know what will.
The battery shorted out because I forced it in when I upgraded to the brass battery tray. I did this right before my race and rushed it. I paid the price for that stupid move!
I did see the front universal being an issue for a driver and I'm not sure if that is going to be addressed any time soon. I do know for sure that the front wide bumper is a must for this car.
One more thing- my main problem was the fact that the hinge pin for the rear upper arm was a very tight fit. This is not an issue for many cars, but in the V10, we use set screws to secure it as this is our roll center adjustments as well. If that hinge pin does not go in freely and the arm does not move freely after you secure the set screws, then it will not matter what adjustments you make on the car, your rear will not function right as the whole suspension is out of the game. To make matters worse, if you didn't set your camber adjustment screw center into the upper arm, then when you give yourself more camber you will force the screw into the plastic and pin the hinge pin against the plastic. That too will freeze your rear suspension. I had both of those issues. I learned a big lesson this weekend and hopefully this post will prevent some of you from going down that road.
Desoto Racing
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Sheperd Velox moy Nitro On-Road 585 04-19-2012 09:51 AM
Serpent 733 vs. Shepherd Velox V10 Geberit Nitro On-Road 27 07-06-2009 04:28 PM
Upgrade/ RCiD ryno1922 Nitro On-Road 26 03-31-2009 01:49 PM
Shepherd Velox V10 macaurc Nitro On-Road 31 03-02-2009 08:35 AM
