Old 07-01-2011, 07:11 PM   #1036
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Default v10
I know this isnot the place, I have a v10 for sale!! pm me for details
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "D815 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / ko propo RSX / FUTABA 4PX / Novarossi
1evo RRR Driver is offline   Reply With Quote
Old 07-03-2011, 12:12 AM   #1037
zosman's Avatar
bro foto pls n how much $$$?
My hobbies is Rc
zosman is offline   Reply With Quote
Old 07-04-2011, 05:23 AM   #1038
Bundy_Bear's Avatar
Default Build Questions
Hi
Just wondering where everyone is installing their personel transponders? Also how to I get the bellcrank steering system pull up and down from lock to lock? Would a shim do it and if so on the top or underneath?
Andrew
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 07-04-2011, 05:59 AM   #1039
Found the best place for transponders for me is just stuck to the top of the steering servo.
As for the movement in the bellcrank, are you building a 2011 kit with the harder servo saver spring? If not try fitting one of those, I only really see movement in mine if I have to much lock dialed into my transmitter.
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 07-04-2011, 03:17 PM   #1040
Bundy_Bear's Avatar
Hi
It's a 2010 model
MissMooRC Racing
Old 07-04-2011, 03:38 PM   #1041
Originally Posted by Bundy_Bear View Post
Hi
Andrew
Hi Andrew,
if you have the enclosed reciever box put the transponder in with your reciever. Thats were i put mine with the enclosed box. Otherwise as Jas1 said place it on top of the steering servo.
Re the play in the bellcrank just place a shim at the top thats all i did to solve this.
Also just use the stock setup that it comes with it is very drivable straight out of the box with it.
ps - about time you got a real rc car
Cheers,
Michael
Mike Schroder is offline   Reply With Quote
Old 07-04-2011, 04:15 PM   #1042
blis's Avatar
Guy had his first real outing with his Velox, Jeff helped stiffen the front diff and suggested we soften the rears a little more as the car's rear was stepping out exiting corners. I think it has a little to do with setup and driving style.
The Front pulley grub slipped again so now set two with loctite. Other than that the results were very promising, we were running the new capricorn engine on the rich side and times on a slippery track were very good.
Bring on the Queenslands.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 07-04-2011, 05:35 PM   #1043
Merrillizer's Avatar
Hi
Andrew
I'm running my transponder on the back of my throttle servo under the top deck. It requires a little modification of the plastic brace, but works great and keeps it away from fuel. I'm using a RC4, should work with a MRT, not sure about the old AMB.
For the steering bellcrank, I've found that you need to put a couple shims between the bearing and top deck to eliminate all the slop. Hard spring as well.
I keep a fresh can of alphabet soup in my pit bag.
Merrillizer is offline   Reply With Quote
Old 07-05-2011, 03:25 AM   #1044
Bundy_Bear's Avatar
Originally Posted by Mike Schroder View Post
Hi Andrew,
Cheers,
Michael
Hi Michael
It is just the standard kit so no receiver box at this stage and i will try the shims and see what difference it makes...
Real car.... LOL
Are you talking about the Edam cause that is the same car you drove or the Team Magic
Shepherd goes together very well, the plastic does have a Team Associated/Thunder Tiger look and feel to it though.
Andrew
MissMooRC Racing
Old 07-05-2011, 03:28 AM   #1045
Bundy_Bear's Avatar
Thank you
MissMooRC Racing
Old 07-05-2011, 04:12 AM   #1046
Bundy_Bear's Avatar
Default Shock Length
I have just finished adjusting the shocks to the lengths advised on the Shepherd website. Does anyone have a concern with 69.5mm on the front and not having much thread left on the bottom ball end?
Andrew
MissMooRC Racing
Old 07-05-2011, 04:16 AM   #1047
Andrew
Andrew are you using the correct ball ends cause i have heaps of thread in my front shocks, keep in mind the shock shafts are short on the front and long on the rear.
Old 07-05-2011, 04:59 AM   #1048
Bundy_Bear's Avatar
Mike:
I did use the right shafts, as for the ball ends i am not sure, i just used the ones that came in the shock bags...
Here is a picture to show what i mean!
Andrew
MissMooRC Racing
Old 07-07-2011, 04:34 AM   #1049
Bundy_Bear's Avatar
Mike:
Andrew
Anyone? Feel the love for this bear....
MissMooRC Racing
Old 07-07-2011, 08:08 AM   #1050
G87z's Avatar
correction I found it burried in their news section. I will go home and measure mine this evening.
Bundy,
Where are you getting that length from? I do not see it anywhere on the Website or the manual? I just built a set of those shocks and i have one thread showing on the piston.
Let me know.
George
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Sheperd Velox moy Nitro On-Road 585 04-19-2012 09:51 AM
Serpent 733 vs. Shepherd Velox V10 Geberit Nitro On-Road 27 07-06-2009 04:28 PM
Upgrade/ RCiD ryno1922 Nitro On-Road 26 03-31-2009 01:49 PM
Shepherd Velox V10 macaurc Nitro On-Road 31 03-02-2009 08:35 AM
