Old 05-02-2011, 04:43 PM   #1006
blis's Avatar
Default Replies.
It was a run in session for engines and clutches. With the very few laps at moderate speed my son really liked the feel of the car. Having driven TM's for 3 years, it's not surprising it would feel good.
The clutch loosened up and glad to hear the bearings are durable, will use it until it fails.
MS, Yes Jeff is a good buddy and we have his support as well. Just dont have the front sway blocks in stock and will get them.
Short of the third post that Guy made himself (courtesy to M Rheinhard) for the idea, it's stock 2011 and we changed the body post pivot thingies from TM.
Looking forward to see it in full flight and will capture some footage to post on our bumpy track.
h
PS: Jeff World's Shell makes it go faster too!
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 05-06-2011, 02:30 AM   #1007
To all Shepherd drivers!!!
Shepherd Micro Racing is working on some changes for U.S. distribution.
Please give us a week more to announce the final facts.
You can be sure that all Shepherd Products will be available in the next two weeks.
We are sorry for this situation.....
Best Regards
Armin
Shepherd-Micro-Racing
veloxrc is offline   Reply With Quote
Old 05-08-2011, 01:23 AM   #1008
Send a message via MSN to PMSorber
Shepherd V10 is European B champion after an awsome thrilling race.
http://www.redrc.net/2011/05/patrick...200mm-b-title/
Congratulations Patrick Nähr!
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 05-19-2011, 04:49 AM   #1009
Thumbs up
Hey guys,
Thought I would share some pic's of my Velox V10, I have fitted a fair few Team-C hop ups and they fit excellent.
So far the car has helped me do my personal best at my local track.
It is a 2010 with all the 2011 upgrades I use RB engines which I can't fault.
Awesome car Shepherd keep it up.
Michael Schroder
Mike Schroder is offline   Reply With Quote
Old 05-19-2011, 04:20 PM   #1010
blis's Avatar
Default Looks great..
Originally Posted by Mike Schroder View Post
Hey guys,
Michael Schroder
Are the pink springs harder? And do you use the standard front droop part or the Alu ones?
Old 05-19-2011, 06:16 PM   #1011
olhipster1's Avatar
Trader Rating: 96 (100%+)
Send a message via Yahoo to olhipster1
Default more eye candy
some more eye candy for everyone
Shepherd Velox V10-img_0058.jpg   Shepherd Velox V10-img_0050.jpg   Shepherd Velox V10-img_0048.jpg   Shepherd Velox V10-img_0060.jpg
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 05-19-2011, 07:25 PM   #1012
Hi H,
Nah the springs are xray pink ??? I think (not sure of xray colours and ratings there to close in colour). The spring is softer than the kit green spring which I have been running I will try them soon.
I use the team c sway bar holder and the std carbon fibre droop adjusters.
Old 05-24-2011, 06:46 PM   #1013
nomorals09's Avatar
I need help!!
I bought 2 v10's. The problem is that the pivot balls in one kit are too long. With them screwed all the way in, the car is too wide---204mm. These are black in color.
I have a race this weekend and no time to get replacements from Shepherd. Does anyuone know if any other brand pivot balls will work?
Thanks for any help.
nomorals09 is offline   Reply With Quote
Old 05-24-2011, 11:44 PM   #1014
Originally Posted by nomorals09 View Post
I need help!!
All I did with mine on the rear was cut down the threads by 3mm on both sides. Pivot ball still goes into the arm with plenty of threads and gives you alot more adjustment.
Or place all your shims on the axle first then insert into the bearings so all the shims are on the inside for now.
hope this helps good luck on the weekend............
Old 05-25-2011, 10:33 AM   #1015
Seisick's Avatar
I need help!!
dremel it, but check before if your rear tires are 2 degree offset?
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 05-25-2011, 07:07 PM   #1016
nomorals09's Avatar
Thank you guys
Old 05-26-2011, 12:46 PM   #1017
V-10 Dudes,
Need some help. The front steering blocks on my car are a weak link to having a good race weekend or spending to much time in the pits replacing a Steering block.
I am constantly having to replace or just put the steering ball back thru the steering block. Normally, it is the lower ball that is pulled out of the block.
Has any tried a different brand of steering block to see if the axles and dog bones will work? (Kyosho, Mugen, X-Ray)
It would be nice to say that I will never hit anything, but the only way that will happen is if I do not put the car on the track with another car.
Thanks,
XPHamer is offline   Reply With Quote
Old 05-26-2011, 01:55 PM   #1018
Merrillizer's Avatar
I've had good luck with Mugen MTX4 knuckles. You'll need the knuckles, pivot balls/caps, bearings, and wheel axles. The Shepherd cvd shafts will work. This setup is much stronger than the stock stuff, but heavier.. I switched back to the shepherd setup for lighter weight.
Another thing to consider is the bumper. With the foam bumpers, I've had lots of problems pulling pivot balls through the knuckles, even just 'scuffing' a pipe. But once I was able to get some of the wide plastic lower bumpers, I've had zero issues. It seems to bounce off of the wider bumper instead of pulling wheels off. The downside is that you will break the bumpers if you hit a wall 'direct' at speed.
I keep a fresh can of alphabet soup in my pit bag.
Merrillizer is offline   Reply With Quote
Old 05-27-2011, 01:16 PM   #1019
MrSlow's Avatar
Joining the V10 family. Robert at Ashford Hobby has a great selection of parts for the car (though I think I got his last kit before the first Shepherd America shipment arrives). I am very enthusiastic about the addition of Shepherd America and expect good things to come. Once the US Team is formed there should be much more discussion here, not to mention next years worlds--many elite drivers on the international team running the V10.
Please share any tech advice for this build.
Cheers / Jason
MrSlow is offline   Reply With Quote
Old 05-27-2011, 05:57 PM   #1020
blis's Avatar
Hi H,
Hey Mike,
It was a the front sway bar retainer with the grub screws that stripped.. waiting on Jeff to get alloy ones in stock. We took it for a run and a grub screw on the front pulley failed and allowed the pulley to slip out, even with the pulley hanging out the car behaved quite well considering it was only rear wheel drive and the pulley was rubbing on the pipe.
Looking forward to a clean run in the near future.. will keep ya'll posted. So far it looks great!
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Sheperd Velox moy Nitro On-Road 585 04-19-2012 09:51 AM
Serpent 733 vs. Shepherd Velox V10 Geberit Nitro On-Road 27 07-06-2009 04:28 PM
Upgrade/ RCiD ryno1922 Nitro On-Road 26 03-31-2009 01:49 PM
Shepherd Velox V10 macaurc Nitro On-Road 31 03-02-2009 08:35 AM
