Old 02-24-2011, 09:34 PM   #976
MrSlow's Avatar
MrSlow is offline   Reply With Quote
Old 02-25-2011, 12:13 AM   #977
@ olhipster1:
if you have the old knuckles the bearing play should be quite big; you can get the new knuckles free of charge through your local dealer or distributor.
www.team-shepherd.com - www.sonic-engines.com
Trick is offline   Reply With Quote
Old 02-27-2011, 11:09 AM   #978
the v10 'eleven' is now in stock over in the uk, so should be available everywhere anytime
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 03-05-2011, 09:06 AM   #979
beautiful kit. everything fits together smoothly like butter. i am loving it.
you also get the original parts as well as the upgrades. accidentally i installed the original diff shafts (too much excitement, too little attention) so I am keeping the ultra light ones as spares.
everything is divided nicely into individual bags and each bag has smaller bag insides with all the parts needed in each step in the manual. it makes it so easy to assemble when you don't have a million screws of different sizes in a bag.
omegaf is offline   Reply With Quote
Old 03-05-2011, 10:41 AM   #980
Glad you like it mate! Spoke to Dave the other day n he said he was sending the 1st kit out to someone in London, I guessed it was you
Enjoy
Speedmerchant WGT
Old 03-05-2011, 12:00 PM   #981
haha, most likely it was me.
yea the kit is lovely. so far i haven't had to sand down anything to make it fit. everything goes together smoothly.
the only funny thing is how the suspension and steering arms move as the drive rotates but i gather that this is a universal downside of all CVD. I am guessing a 5 min run will wear it down enough to make it smooth. The shafts fit quite tightly in the diff cups despite the gratuitous graphite grease application.
The only other thing was a tiny screw missing from the pack but it didn't prevent me from putting everything together, I am just missing one of the small screws that hold the brake disks to the rear diff. Dave is sending me a pack of screws so all is good. It would work as it is anyhow because there are 3 other screws holding the disk to the diff. From the looks of it, 2 screws is enough to hold the disks to the diff.
I am now putting together the servo saver. The instructions are so clear and easy to follow. Everything is in steps and each step has a corresponding bag that includes all the parts you need for the step so i don't have a million screws all over the place and i don't have to go through dozens of plastic parts to find the one i want.
The kit is beautifully engineered and designed and cost much less than my first kit which was full of problems.
Old 03-06-2011, 04:40 PM   #982
Thumbs up
Hey Guy's,
Got my Velox V10 2010 a couple of weeks ago, I have built and had it on the track last week and I tell you now it will take a lot to get me away from this car it is so easy to build easier to maintain nad so far with a few little adjustments easier to drive.
So far working on the car it seems every thing is very simple it took only a couple of minutes to change out the front gear diff to a spool diff and not much longer to change the rear diff oil a well.
The only downfall I have so far found with the car is the guy driving it .
Couple of small things to take not when building would be when assemblying the 2 speed you may need to trim down the OD of the head of the screw so it dosn't bind at all in the change of gear and also possibly a 2-3mm shorter srcew. The only other issue I found was some vertical movement in the servo saver so I placed a small shim between the radio tray and servo saver bearing and this fixed the issue straight away.
All the early issues when the car was first released have been rectified like the sloop in the hubs etc.
I have placed the kit setup on the car it was very balanced straight out of the box. I think some little tweaks with the shock oils and springs this car will be awesome.
Mike Schroder is offline   Reply With Quote
Old 03-08-2011, 08:28 AM   #983
ok mine is now waiting for servos and engine. I mounted the receiver (spektrum 3300 telemetry) and i noticed that the receiver hands about 1mm below the chassis. with the suspension fully compressed the receiver hits the ground. is there anything i can do to prevent this? I would also like to prevent the chassis from hitting the ground at full compression of the suspension. I figured that i can achieve this by adjusting the screws on the dampers but then that will also make the suspension stiffer. any ideas?
Old 03-08-2011, 04:02 PM   #984
You can buy the enclosed receiver case which sites a bit higher and also protects the receiver. Can't remeber part number but it is a Shepherd product.
Old 03-08-2011, 06:37 PM   #985
Here is the part your local Shepherd dealer should be able to sort it out for you.
Old 03-09-2011, 10:53 AM   #986
you must be running quite a larger receiver if it sticking out the bottom of chassis mate, i run futaba which are large compared the the like of ko and spektrum and mine has easily 3-4 mm clearance, all i can suggest is add shims or washers to raise the receiver mount up slightly on the radio tray
as for the chassis, if you still planning on not running on a track with the car your gona struggle not to mark the underside of your chassis if thats what your after mate
Speedmerchant WGT
Old 03-09-2011, 11:10 AM   #987
well i had mounted the receiver under the top deck and that made it hang lower than the chassis. now i mounted it on top of the top deck and it is well above the ground.
The instruction manual shows the receiver mounted under the top deck and the screws on top. That made my receiver hang below the chassis. Mounting it on top gives me lots of clearance from the ground. it's a spektrum 3300T
Old 03-09-2011, 04:52 PM   #988
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default 2011 Shepherd Cup Malaysia w/ Jilles Groskamp TQ
+ YouTube Video
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 03-15-2011, 05:20 PM   #989
nomorals09's Avatar
Where can I get the Shepherd Shock Tool?
nomorals09 is offline   Reply With Quote
Old 03-17-2011, 07:22 PM   #990
Z
I would also like to know this.
www.heartofamericaseries.com
2007 RC Pro Series National Champion - Expert Sedan
2005 ROAR Region 8 Nitro Sedan Champion
Stay Thirsty My Friends
Z is offline   Reply With Quote
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Sheperd Velox moy Nitro On-Road 585 04-19-2012 09:51 AM
Serpent 733 vs. Shepherd Velox V10 Geberit Nitro On-Road 27 07-06-2009 04:28 PM
Upgrade/ RCiD ryno1922 Nitro On-Road 26 03-31-2009 01:49 PM
Shepherd Velox V10 macaurc Nitro On-Road 31 03-02-2009 08:35 AM
