Old 01-19-2011, 04:54 AM   #946
In the next days we will define the final configuration, stay tuned!
Best regards
Patrick
www.team-shepherd.com - www.sonic-engines.com
Trick is offline   Reply With Quote
Old 01-23-2011, 12:39 AM   #947
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
Where can I purchase the Sheperd VCC spring online from??
RC-Mushroom and Amain are my main sites and they both have it backorder...
eBay user id: riketsukirai
Selling all my MTX4 parts, bodies, radio and everything!
Riketsu is offline   Reply With Quote
Old 01-23-2011, 02:17 AM   #948
Originally Posted by Trick View Post
Hey there!
As the V10 is only one year old, we don't bring out a new version this year. Only some smaller optional parts will be included in the kits.
Best regards
Patrick
There will be a V10 "eleven"! The distributor in Switzerland is making preorders for those kits. I don't know which main differences there will be, but a V10 "eleven" is going to be on the market soon.
Italboy is offline   Reply With Quote
Old 01-23-2011, 10:57 PM   #949
Send a message via MSN to PMSorber
Strange, its all on stock:
http://www.rccar24.com/artikeldet.ph...80909a9de416c7
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 01-23-2011, 11:15 PM   #950
NitroWD's Avatar
Originally Posted by PMSorber View Post
i've observed that the springs are indicated with blue or purple, is there any difference? same p/n for both.
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 01-23-2011, 11:21 PM   #951
tcmodels's Avatar
that was V8 Eleven
www.tcmodels.net - online hobby shop
tcmodels is offline   Reply With Quote
Old 01-24-2011, 02:22 AM   #952
Hey there!
At the moment there is a shipment on it's way to Josh Cyrul, our US distributor. So the US shops should have the springs back in stock soon.
There will be a Velox V10 "Eleven" too, but as mentioned before, it "only" contains some additional option parts. Stay tuned for more infos coming soon.
Best regards
Patrick
Old 01-31-2011, 12:47 PM   #953
Just found details of the new v10 eleven spec on 3hobby.net
http://3hobby.net/news/44-rcvehicles...-qelevenq.html
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 01-31-2011, 01:43 PM   #954
Hi,
there is only one Spring available and this is what you looking for!
Part # 410407
A-Man
Shepherd Micro Racing
veloxrc is offline   Reply With Quote
Old 01-31-2011, 08:11 PM   #955
Hi Thunderbunny , i had that problem and that happend because with the use of the belt tensioner screw, the plastic of the roll bar don´t tight enough after some races of use, causing the side belt broke or fast wear , i fix this problem using a longer screw with a lock nut inside the roll bar, then you can tighten the nut as much as you want and it will not move never again, we are 6 velox v10 drivers in México and all have this mod done to our cars. Hope this can fix your problem. here are some photos
Rodrigo
Originally Posted by Thunderbunny View Post
Has anyone else been having problems with stripping spur gears (mostly 2nd gear). I am very competetive with this car but I frequently suffer DNFs due to stripped gears. Also, I''ve noticed that the side belt is pretty loose even with the tensioner on the tightest setting. At the worlds I saw that Marc ran an additional side belt tensioner. Is that an available Shepherd option? Thanks.
lrmc is offline   Reply With Quote
Old 02-13-2011, 03:18 AM   #956
xr8man's Avatar
Default re velox v10
first time out with the new car no real problems apart from the rear end stepping out on fast corners can anyone tell me how to stop this have tried
shock oils roll centers cambers castors running out of ideas i am running a locker in front with 80k rear diff any help would be greatful
MUGEN SEIKI| NOVAROSSI ENGINES | | HEI INTERNATIONAL | MOONSHINE RACING FUEL | SAVOX | FUTABA | HUDY
xr8man is offline   Reply With Quote
Old 02-13-2011, 03:59 AM   #957
What rear end setup are you currently running?
I run near kit setup apart from lower hinge pins lifted and 650cst oil, then with 3 deg toe in the rear is absolutely planted, usually end up just backing the toe in off till I get the right balance
Speedmerchant WGT
Old 02-13-2011, 05:09 PM   #958
MrSlow's Avatar
Default Eleven release date?
what is the expected release date for the v10 ELEVEN in the United States? When will we find it in shops? thanks
MrSlow is offline   Reply With Quote
Old 02-13-2011, 05:28 PM   #959
velox v10 2011 version for the uk? is it coming soon? can i preorder from somewhere?
omegaf is offline   Reply With Quote
Old 02-13-2011, 11:16 PM   #960
DH Modelsport is the uk distributor mate, should be here in a couple of weeks, you after another car now?
Speedmerchant WGT
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Sheperd Velox moy Nitro On-Road 585 04-19-2012 09:51 AM
Serpent 733 vs. Shepherd Velox V10 Geberit Nitro On-Road 27 07-06-2009 04:28 PM
Upgrade/ RCiD ryno1922 Nitro On-Road 26 03-31-2009 01:49 PM
Shepherd Velox V10 macaurc Nitro On-Road 31 03-02-2009 08:35 AM
