Old 10-12-2010, 02:42 AM   #931
hey there!
the updated front knuckles don't have a new number. We have sent out replacements for the old ones to all our distributors so they should already have them in stock.
You find some setups on our homepage, unfortunatly I can't post url links here.
Best regards
Patrick
www.team-shepherd.com - www.sonic-engines.com
Trick is offline   Reply With Quote
Old 10-12-2010, 04:14 PM   #932
Kraceway's Avatar
Default 2010 Kraceway 5th Annual U.S.Open Championship
If you still have the itch to race & wanna race with the factory drivers
November is the time come check it out
November will be the place to race especially with perfect weather
Paypal payment option available www.kissrcraceway.com
Thanks in advance & look forward to those that can attend
Track pics will be posted & if u need more track time we will be having the Forgass State race the weekend before www.forgass.com
Kraceway is offline   Reply With Quote
Old 01-13-2011, 10:17 AM   #933
Thunderbunny's Avatar
Trader Rating: 22 (100%+)
Default Stripped gears
Has anyone else been having problems with stripping spur gears (mostly 2nd gear). I am very competetive with this car but I frequently suffer DNFs due to stripped gears. Also, I''ve noticed that the side belt is pretty loose even with the tensioner on the tightest setting. At the worlds I saw that Marc ran an additional side belt tensioner. Is that an available Shepherd option? Thanks.
Chris Jones a.k.a. "Black Jesus"
O.S. l Airtronics l RSD l
DeSoto Racing l Gulf Coast Raceway Porter,Tx
Thunderbunny is offline   Reply With Quote
Old 01-13-2011, 08:41 PM   #934
Merrillizer's Avatar
Check all of your 2 speed and clutch bearings, also make sure the 2 speed clutch air gap is set right.
The V10 2 speed clutchbell has some tolerance issues. The bearing is a very light press fit and will work its way loose without any precautions. If the bearing slides out while you are running, it's done. Replace it with a good bearing and use loctite or permatex bearing retainer. As an extra precaution you can score the clutchbell with a flathead screwdriver to create a small lip that captures the outer race of the bearing.
The double roller belt tensioner is a Team-C part and is available at tcmodels.net
I keep a fresh can of alphabet soup in my pit bag.
Merrillizer is offline   Reply With Quote
Old 01-13-2011, 10:33 PM   #935
Thanks!
Old 01-13-2011, 11:50 PM   #936
Geberit's Avatar
First look that the teeth of the Pinion and Spur gear are perfectli parallel (no angle), if they tuch in an angle this will cause a prematurely failure of the Spur gear. Look at the Pinion and see if they wear evenly across the whole teeth.
Also when the Pinion get too worn out they damage the Spur gear. Look at the Tooth profile on the Pinion and when you see they are worn, dont wait too long and exchange them.
For the side belt I use a tentioner from TeamC but it's not an ideal solution for me since it's in the way when I want to get the engine out if Shepherd dont come up with something I will make a belt tentioner myself like on Marc's car.
Regards
Geberit is offline   Reply With Quote
Old 01-14-2011, 06:59 AM   #937
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
Hey guys, what clutch spring are you guys using??
How is the VCC spring compared to other springs like the Mugen Hard or the Orion Square Spring??
Will the VCC spring fit clutches like the Xray or Capricorn??
eBay user id: riketsukirai
Selling all my MTX4 parts, bodies, radio and everything!
Riketsu is offline   Reply With Quote
Old 01-14-2011, 07:27 AM   #938
My gears looks good, but I did notice that the 2-speed clutch bell did lose the initial tight fit of the bearing which I plan on replacing. As far as the VCC clutch spring, I think it works well. Although, I do plan on trying the new yellow clutch shoe. I like the bite of the stock one, but it does seem to wear a little more than I've seem on previous cars that I've owned. It's mainly due to the style of my home track which is technical and high grip.
-Geberit, if you decide to make a tensioner, let me know. I'll buy a couple from you.
Old 01-14-2011, 07:37 AM   #939
Geberit's Avatar
This is a nice thing...
http://www.redrc.net/2010/09/dnm-tec...p-touring-car/
in US you can buy here: http://www.teammarketingamerica.com/
Regards
Old 01-14-2011, 11:14 AM   #940
Another thing to check if your stripping gears, I had a bent 2 speed shaft, the gears grounded out on a track marker and slightly bent the shaft, just a thought
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 01-18-2011, 12:56 AM   #941
Default v10 eleven?
hi !
i'm thinking about to buy another v10.
but i just saw on redrc the new v8'eleven'
may i have to wait for the new """" v10'eleven' """"" ?
or buy a v10 and there will be some upgrades for it
thanks
chrys
Chrystoforo is offline   Reply With Quote
Old 01-18-2011, 01:10 AM   #942
Send a message via MSN to PMSorber
Originally Posted by Chrystoforo View Post
hi !
thanks
chrys
I dont know if there are developments that will result in the same changes for the V10 within the short term.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 01-18-2011, 03:54 AM   #943
Hey there!
As the V10 is only one year old, we don't bring out a new version this year. Only some smaller optional parts will be included in the kits.
Best regards
Patrick
Old 01-18-2011, 10:24 AM   #944
Originally Posted by Trick View Post
Hey there!
Best regards
Patrick
Thank you very much!
Chrys
Old 01-19-2011, 05:07 AM   #945
velorossi's Avatar
Hey there!
Best regards
Patrick
And which "smaller option parts" it will be??
Regards Kurt
velorossi is offline   Reply With Quote
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 06:51 PM
Sheperd Velox moy Nitro On-Road 585 04-19-2012 10:51 AM
Serpent 733 vs. Shepherd Velox V10 Geberit Nitro On-Road 27 07-06-2009 05:28 PM
Upgrade/ RCiD ryno1922 Nitro On-Road 26 03-31-2009 02:49 PM
Shepherd Velox V10 macaurc Nitro On-Road 31 03-02-2009 09:35 AM
SEO by vBSEO 3.5.0
