Old 06-01-2010, 01:59 PM   #841
NikoRacing's Avatar
Originally Posted by coupe View Post
Hey Nico,
i guess they could fit, it is a 10mm outside diameter, the inside is the same diameter like xray, the only thing i am not sure is if you have enough space for the clamping ring at the inside of the hub !!!
But i think the wheelaxles are only something about 18 or 19 euros the pair, so buy some and try.
Alex
At the moment I'm using the Capricorn wheel axles on my NT1 and the clamping ring has all the space to stay in. They are very similar to the Velox' ones in the design.
The steering block of the NT1 is 12 mm large (4mm for each ball bearing and 4mm of space between them).
Capricorn's wheel axles have a 13.5 distance to allow to set the offset of the car. It means that there are 1,5mm to fill with some shims.
http://www.capricornrc.com/os_capric...roducts_id=841
Can you please take some measure on you Velox?
Thank you Alex
NICOLA PEZZOTTI - italian F1 cat. driver - Serpent 747 - HIPEX exhaust system - HOTRACE tyres - SANWA M11X
NikoRacing is offline   Reply With Quote
Old 06-01-2010, 02:27 PM   #842
DS Motorsport's Avatar
Thank you Alex
The V10 wheelaxles are 13.8-14.0 and they will fit the NT1 without a problem. You can also use the NT1 driveshafts with the V10 wheelaxle without a problem.
I already checked it when the V10 was released incase of the V10 wheelaxles being cheaper as the Capricorn one's but I decided to stick with the original stuff.
But the aluminum wheelaxles are pretty interesting, do hope the hardcoating is of good quality(not questioning Shepherd, but I've seen some very bad coatings and some very good one's, Hudy Tooling) because once that wears off the cvd pinhole will wear out in no time.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 06-02-2010, 05:45 AM   #843
musti72's Avatar
So can anyone measure the weight of the Shepherd's new aluminum, or standart wheel axle piece?
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 06-02-2010, 06:48 AM   #844
Geberit's Avatar
Standard wheel axle 6.6g! So the aluminum should be 60% less (read Shepherd home page) that means 2.7-3g in theory ...
Geberit is offline   Reply With Quote
Old 06-02-2010, 06:49 AM   #845
the aluminium are 4gr each !
coupe is offline   Reply With Quote
Old 06-02-2010, 01:33 PM   #846
NikoRacing's Avatar
Thank you all for the infos
I think I'm going to buy some couple of this aluminium wheel axles and using it with the original xray's driveshafts.
Thx
Niko
Old 06-03-2010, 10:50 AM   #847
jaykay's Avatar
Im just building my v10. Have you also got the problem, that the brake pads are grinding at the brake disc, so that the car dosnt run free?
jaykay is offline   Reply With Quote
Old 06-03-2010, 01:13 PM   #848
Rick Vessell's Avatar
The brake spacing out of the box is tight. You can either:
Sand the pads slightly to increase clearance, this will require the pads to 'break in' though and braking power will be decreased until they 'run in'
Run the car for a few tanks working the brakes until they loosen up.
Either way when the brakes are 'run in' you'll only need about 30-35% travel. The brakes on the V10 are great and do not wear. You will have the same stopping power on the first lap and the last lap.
Rick Vessell is offline   Reply With Quote
Old 06-04-2010, 02:52 AM   #849
jaykay's Avatar
what have most of you done with the brake pads? sand it?
Old 06-04-2010, 07:10 AM   #850
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
yeah i sanded mines, but realized tht after i ran the car a couple of times the spacing would hav been perfect from the natural wear..........
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "D815 PILOT" /FUSION X3LCFM / M2c / ko propo RSX / M11x / Novarossi
1evo RRR Driver is offline   Reply With Quote
Old 06-04-2010, 09:38 AM   #851
jaykay's Avatar
ok. i sand it.
fits perfect now. im sure after some tanks it will fit perfectly.
Old 06-04-2010, 02:01 PM   #852
Thunderbunny's Avatar
Trader Rating: 22 (100%+)
I wore my breaks in. I ran about 2-3 tanks during the first few practice sessions.
Chris Jones a.k.a. "Black Jesus"
O.S. l Airtronics l RSD l
Team ARC l Gulf Coast Raceway Porter,Tx
Thunderbunny is offline   Reply With Quote
Old 06-06-2010, 08:12 PM   #853
SnakeEyz's Avatar
Default Gearing
I would like to know if anyone could tell me what gearing comes with the stock kit. Trying to figure out which extras to order.
SnakeEyz is offline   Reply With Quote
Old 06-06-2010, 08:31 PM   #854
SnakeEyz's Avatar
Default Pinnions
Also i was wondering how long are the hardened aluminum pinnions lasting. Im coming over from kyosho in which i used steel pinnions and they lasted forever. Just trying to get a general idea of what spares i need to order thank you.
Shepherd Velox V10/ KO Propo/ Novarossi Engines/ Team NLR/ V.O.R.R.A./ 301(Forever)/ AKA. Darryl Hurling
Old 06-07-2010, 03:18 PM   #855
Chickentrader's Avatar
Steel pinions last longer in any brand of car. Hardened will make your clutch bell lighter and pick up revs faster (less momentum).
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Sheperd Velox moy Nitro On-Road 585 04-19-2012 09:51 AM
Serpent 733 vs. Shepherd Velox V10 Geberit Nitro On-Road 27 07-06-2009 04:28 PM
Upgrade/ RCiD ryno1922 Nitro On-Road 26 03-31-2009 01:49 PM
Shepherd Velox V10 macaurc Nitro On-Road 31 03-02-2009 08:35 AM
