Old 05-24-2010, 06:18 PM   #826
tcmodels's Avatar
anyone try the new solid axle ?
www.tcmodels.net - online hobby shop
tcmodels is offline   Reply With Quote
Old 05-24-2010, 11:56 PM   #827
Send a message via MSN to PMSorber
Default Yes
Some of our Benelux teamdrivers did during the EC-B. What do you want to know?
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 05-25-2010, 02:14 PM   #828
Thunderbunny's Avatar
Trader Rating: 24 (100%+)
Default chassis brace
Has anyone been experiencing any problems with the side chassis brace getting stress cracks around the mounting holes? I replaced one that cracked completely during practice and qualifying runs at the Xray Challenge here in Houston, which resulted in a few sets of stripped spur gears. The problem was solved, but after the races, I noticed that the new one is beginning to crack too. As a side note, I never over tightened the screws. Are there any companies that make an aluminum or carbon fiber replacement?
Chris Jones a.k.a. "Black Jesus"
O.S. l Airtronics l RSD l
Team ARC l Gulf Coast Raceway Porter,Tx
Thunderbunny is offline   Reply With Quote
Old 05-25-2010, 03:24 PM   #829
KHoff7's Avatar
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 05-25-2010, 06:28 PM   #830
mike jones's Avatar
Team C makes an aluminum brace......i ran my car with out the brace a couple of times and never had problems with stripping gears...
SHEPHERD MICRO RACING, CEFX, TEAM C, CONTRAST, PICCO, KO PROPO, NOVAROSSI, BYRON ORIGINALS FUEL, JACO, DCM HOBBIES, JGO PAINTZ
mike jones is offline   Reply With Quote
Old 05-26-2010, 08:27 AM   #831
Thanks. I'll give my car another once over. I might have an issue elsewhere.
Old 05-26-2010, 08:28 AM   #832
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
I've noticed tht also, tht my plastic side brace is cracked, I hav a team c allum one now, but it's a good idea to keep a plastic 1 in stock cause allumin side brace can sometimes change ur cars handleing characteristics, stiffins the car a little, BT I will try running without a brace, I thought about doin it but always felt tht the shep chassis was too flexible and thought I would strip my gears........did u do it for more steering?
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 05-26-2010, 09:00 AM   #833
He guys,
about the brace. Of course we had some cracked ones, but normally they should keep in place. I think sometimes they crack if you have a bumpy track or even a crash. In this case you will have maximum pressure to the screw in the front and the brace will brake.
We also use the car without the brace, the chassi is OK for that, believe me,
the car will be more left/right balanced without it, and the handling is getting a little bit better. We never stripped a gear !!!! And we used it in Herrlisheim, and this track is reaaaly bumpy, but everything was ok.
As a shepherd staff of course i donīt like after market stuff ......
But maybe it is an option, but in the other side it should not be a problem with the standard part.
Oneway/Solidaxle:
We used it at every track we went for racing or testing.
On many tracks its much better with the solid axle, its easier to drive and most of the time faster. BUT, you will have a higher tyre wear !!!
We also used the oneway, these is also fucking fast but really hard to drive as you should not think a lot about braking !!!!
But for the finals and also for the qualifiers we mostly steped back to a differential as we do not have a lot of traction in germany.
But we tried it in Houston, and of course i think on a track like this it is a really good option, especially for the quickchanging corners !!
Thats it
Alex
coupe is offline   Reply With Quote
Old 05-26-2010, 09:30 AM   #834
Geberit's Avatar
Originally Posted by coupe View Post
He guys,
Oneway/Solidaxle:
Thats it
Alex
Hi, Alex!
How is the wear of the CVD-s when using the Solid axle? I had many problems using Solid Axle when I was driving electric touring!
Regards, L
Geberit is offline   Reply With Quote
Old 05-27-2010, 04:56 AM   #835
Hey,
ox course i think they wear out a little bit faster, but i am still running the ones from Houston !! So i think this should not be a problem.
We also are using the aluminium Wheelaxles, i am really super satisfied with them. They will drop down the weight 16gr in total !! We used them at the last race in Ettlingen with two cars all the weekend, Patricks car unfortunately not in the final, after a clear TQ the engine stoped after i droped it for the start, and car number 8 i think was taking him out in second gear !!! Bad bad luck, even as we found some speed for the final and could run easily 13,7 in the warm up !!!!!! Nearly faster like in the Qualifying ! But we had no wear at the parts so i think this is helpful to find some extra speed.
Back to work
Alex
Old 05-28-2010, 03:00 PM   #836
fresh_trf's Avatar
Trader Rating: 19 (100%+)
Hi guy,
I just got v10 and don't have engines yet . I don't know what engines is good . please help me about engines.
thank you.
fresh_trf is offline   Reply With Quote
Old 05-28-2010, 05:29 PM   #837
Default Engine
I run the Novarossi Flash Tuned. Very fast and dependable motor. A bit pricey though. If you're on a budget, try the Sirio Evo4, Pico Red Dot, or the RB Junior 9. You can get any of the three for $200 or less.
Old 05-29-2010, 01:05 AM   #838
fresh_trf's Avatar
Thank you very much.
Old 06-01-2010, 12:58 PM   #839
NikoRacing's Avatar
Hello!
Any of you knows if the wheel axles of the V10 can fit the xray NT1??
I've just seen that Velox has introduced aluminium lightweight wheel axles and I think they're spectacular.
I hope any of you can reply to my answer
http://www.redrc.net/2010/06/shepher...t-wheel-axles/
Thx
NICOLA PEZZOTTI - italian F1 cat. driver - Serpent 747 - HIPEX exhaust system - HOTRACE tyres - SANWA M11X
NikoRacing is offline   Reply With Quote
Old 06-01-2010, 01:32 PM   #840
Hey Nico,
i guess they could fit, it is a 10mm outside diameter, the inside is the same diameter like xray, the only thing i am not sure is if you have enough space for the clamping ring at the inside of the hub !!!
But i think the wheelaxles are only something about 18 or 19 euros the pair, so buy some and try.
Alex
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Sheperd Velox moy Nitro On-Road 585 04-19-2012 09:51 AM
Serpent 733 vs. Shepherd Velox V10 Geberit Nitro On-Road 27 07-06-2009 04:28 PM
Upgrade/ RCiD ryno1922 Nitro On-Road 26 03-31-2009 01:49 PM
Shepherd Velox V10 macaurc Nitro On-Road 31 03-02-2009 08:35 AM
