Old 05-02-2010, 02:16 AM   #811
Hey,
the clutch is completely different. The V8 parts will not fit.
In the moment we only offer the standard black one as we are very happy with that one !! We tried some other and most of the time we went back to the black standard. If you wanna try something different sou can use the IDM / Capricorn clutch shoes, they offer yellow, green, blue and red i think ! They will nearly fit to the V10 clutch. But one more time, the black one is really a cool thing. You just need to play a little bit with the adjustments to make it fit to your style. What we use in the moment is a spring preload with approx. 0,3, a clutch bell gap of 0,50 to 0,55. This works pretty good so far.
One tech tipp for the clutch, as we realized that some pins of the flywheel are a little bended:
1- Dont use the "special tools" to tighten the flywheel, always use a big plier to hold the flywheel on the outside diameter to tighten the screw !!!
2- To make sure the clutch parts are moving freely i drill the holes as big as they have to be to move freely. Also this helps to get a better performance of the clutch.
H.A.N.D.
Alex
coupe is offline   Reply With Quote
Old 05-02-2010, 09:52 AM   #812
Thunderbunny's Avatar
Trader Rating: 24 (100%+)
Thanks a lot!
Chris Jones a.k.a. "Black Jesus"
O.S. l Airtronics l RSD l
Team ARC l Gulf Coast Raceway Porter,Tx
Thunderbunny is offline   Reply With Quote
Old 05-04-2010, 10:55 AM   #813
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
BT how was the car in Vegas? and were you the only Velox running?
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 05-04-2010, 11:47 AM   #814
mike jones's Avatar
Default Weekend in Vegas
The weekend went by really fast but I learned a lot about the car. I first went out on Friday with the chevy Body and the eccentric flipped. Traction was moderate to medium. Car was a handful to drive... had tons of sterring but not a lot of rear bit. So I went to the R5 body and it calmed it down but I knew it was missing something. So I ran two qualifiers and was sitting fourth or fifth not sure, so i came back to the table and figured I might as well try something new; so I put the light grey springs in the front which are softer and I raised the rear roll center from the bottom to the middle and I put on a Stratus Body and went out and ran the last qualifier. The car was more consistent with this set up and going around the sweeper the rear of the car would not kick out. That run put me second behind Mike Swauger. I ran the same set up in the main and the car was really good, good enough to run with Swauger for the first part of the race then talent took over and I started making mistakes but was able to finish second about 11 seconds behind on the same lap as him so I would say it was a good weekend of racing. Didn't break one part the whole weekend and I traction rolled the car twice and had it slide into the outside boards. The other thing I did was I put set screws in the front and rear up rights to eliminate the axles from moving back and forth ....seem to make the car more planted going around sweepers. Just make sure you don't tighten them to tight on the bearings.
But all and all the car performed awesome, I need to get a hold of the main results sheet to see what my lap times were to compare.
SHEPHERD MICRO RACING, CEFX, TEAM C, CONTRAST, PICCO, KO PROPO, NOVAROSSI, BYRON ORIGINALS FUEL, JACO, DCM HOBBIES, JGO PAINTZ
mike jones is offline   Reply With Quote
Old 05-04-2010, 12:21 PM   #815
Pooh2's Avatar
Send a message via MSN to Pooh2
You the man B.T!!!
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 05-04-2010, 01:52 PM   #816
NICE B.T. !!!! :-)
We are working hard on the new/updated uprights, so the play should be eliminated soon.
We also will have some talent to sell. There will be two packages for sale.
The medium sized one and the XXL sized talent box !! Prices will be published asap.
Hey BT, if possible email me some further information about that race.
Alex
Old 05-04-2010, 10:49 PM   #817
mike jones's Avatar
Originally Posted by coupe View Post
NICE B.T. !!!! :-)
Alex
Real funny Alex, I knew after i typed that someone was going to say something but i didn't think it would be you....lol..
Old 05-05-2010, 07:15 AM   #818
Love you B.T.
Old 05-05-2010, 09:03 AM   #819
Rick Vessell's Avatar
Can I preorder my box of talent Alex?
Congrats on the podium finish B.T.
Rick Vessell is offline   Reply With Quote
Old 05-06-2010, 12:22 AM   #820
Sorry Rick,
this Box is not compatible with you!!!!
Armin
veloxrc is offline   Reply With Quote
Old 05-06-2010, 12:26 AM   #821
Hey thats not true,
Armin only told you this because he took all of the boxes !!!
Old 05-06-2010, 01:12 AM   #822
Send a message via MSN to PMSorber
Hey thats not true,
Ah, German races this weekend... lets wait and see if the designers did a good job on its content.
Good luck guy's!
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 05-07-2010, 07:06 AM   #823
Originally Posted by veloxrc View Post
Sorry Rick,
Armin
Hey thats not true,
Thanks Armin, I'll take that as a compliment.
Old 05-13-2010, 09:20 PM   #824
Team C light weight 2-speed adaptor, we run and test it more than 3 hours
new design flange stop pin comes out
Shepherd Velox V10-snc10895.jpg   Shepherd Velox V10-snc10896.jpg   Shepherd Velox V10-snc10898.jpg   Shepherd Velox V10-snc10899.jpg
Hobbypro / Team C, Hong Kong
www.hobbypro.com.hk
www.teamcracing.net
Picco, IDM, Werks, ATS, Shepherd, Blue Bird
hobbypro is offline   Reply With Quote
Old 05-14-2010, 12:08 AM   #825
Good luck guy's!
Looking at the outcome of the races in Germany last weekend... Lets go selling boxes of Talent!!!!
@ConSult Trading
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Sheperd Velox moy Nitro On-Road 585 04-19-2012 09:51 AM
Serpent 733 vs. Shepherd Velox V10 Geberit Nitro On-Road 27 07-06-2009 04:28 PM
Upgrade/ RCiD ryno1922 Nitro On-Road 26 03-31-2009 01:49 PM
Shepherd Velox V10 macaurc Nitro On-Road 31 03-02-2009 08:35 AM
