Old 04-19-2010, 02:06 PM   #781
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Default 1st outing
BT how did the shakedown go with the v10 at RAMS? Likes/dislikes? 2 of us were headed there, but norcal had 7 for sedan.......
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "D815 PILOT" /FUSION X3LCFM / M2c / ko propo RSX / M11x / Novarossi
1evo RRR Driver is offline   Reply With Quote
Old 04-19-2010, 05:06 PM   #782
mike jones's Avatar
The car worked awesome, I ran the kit set-up with only a few changes like 200,000 wt. front diff oil and 40 wt front shock oil. There wasn't alot of sedan there but it was still a good test session, the car was really good in the morning after we finished breaking in the motor but i made the mistake of tighting the clutch to much and after the main realizing that that was the reason why the motor kept over heating. The traction was desent, and I ran 40 Jaco's front and rear and never had the car even lift the wheel a little. I need to work on gearing and maybe try lowering the roll center in the rear because the track had some waves in it and on heavy breaking the rear of the car would unload a little. I broke the lower ackerman steering mount after hugging a turn to tight but other than that the car was perfect.The average 1/8th scale was running low 15 second lap times and my fastest was a 15.8 with a sedan. Cant wait until next weekend to try it again.
SHEPHERD MICRO RACING, CEFX, TEAM C, CONTRAST, PICCO, KO PROPO, NOVAROSSI, BYRON ORIGINALS FUEL, JACO, DCM HOBBIES, JGO PAINTZ
mike jones is offline   Reply With Quote
Old 04-19-2010, 06:29 PM   #783
Cool, I knew I was on to something with that 200k, that's crazy cause I was also on pace with the fast crowd at norcal and I rubbed a car in The A warmup and broke the same part, and I kno why, I tightened down the saver spring more than usual cause the spring is way to soft. A issue that shep has resolved, with a stiffer spring, but the saver arm should b alluminum........Other than that I think the car is awsome, also try the front diff ecentrics mod the designer posted a few back that it gives more steering in fast corners if u turn them 180degrees, I tried it sunday but I didn't time the normal way, so I can't tell u if it works........and lightened diff internals would b the ultimate.......let me kno wht u figure out as far as setup please, cause I think ur 1 of 2 shep drivers that run American style tracks with amer style traction and amer style boards!
Peace
Old 04-19-2010, 07:05 PM   #784
mike jones's Avatar
Peace
I'm going to give the front eccentrics a try this weekend and play with roll center, I have the aluminum Team C steering ackerman and i thought it would be bullet proof but i forgot the piece underneath is still plastic...lol..But all in all it was really good to get back out on the track with a sedan that works well.
Old 04-20-2010, 01:26 PM   #785
Hey,
nice to hear that everythings working out good so far.
Well the Team C Part is not bad, but i think the piece underneath will be no problem. We didnīt break one, only the top part is a little weak for the us tracks. We also tried to use the plastic internals for the diff, the front will be ok but in rear we broke every diff !! I think the problem is that we have to much torque on the rear diff while breaking. So in the front it is ok, in the rear its not so easy. So we will stay with the standard parts as i can be sure they will stay where they have to be. The plastic internals will only save 8gr at each diff !! So not to much. What we will have soon are the lightweight outdrives for the front and rear differential.
Looking forward for some results of you excentric tests.
Alex
coupe is offline   Reply With Quote
Old 04-20-2010, 07:53 PM   #786
mike jones's Avatar
Originally Posted by coupe View Post
Hey,
Alex
Hey Alex, get your Scion yet......Had a ball testing the car the other weekend... worked right out the box, will try the eccentrics this weekend and will try the chevy body also...I will post results next week.
Brian T
Old 04-20-2010, 07:58 PM   #787
BIREL8's Avatar
Brian T
BT you coming to vegas?
Steven Jackson
KILLA BEEZ
SHEPHERD USA
DESOTO RACING
KOPROPO
BIREL8 is offline   Reply With Quote
Old 04-20-2010, 09:56 PM   #788
mike jones's Avatar
Yes Sir, should be alot of fun...as long as he don't get to crazy with the VHT..
Old 04-20-2010, 09:57 PM   #789
Team Kamikaze's Avatar
He?
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-20-2010, 10:01 PM   #790
mike jones's Avatar
Originally Posted by Team Kamikaze View Post
He?
Rich..
Old 04-20-2010, 10:09 PM   #791
Rich..
Old 04-20-2010, 10:44 PM   #792
Send a message via MSN to PMSorber
Brian T
We did the eccenter testing last weekend during our nationals, worked out great! It gave us just that little more steering on-power at fast corners. It seems to work better.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 04-21-2010, 12:58 AM   #793
Jeff Hamon's Avatar
Hi guys,
i was having a look at Jilles setup for houston and noticed he was running the oneway, i would like to know how much difference the actual geometric setup changed from going from the diff to oneway ie. shocks, springs, toe, roll centres?
Cheers,
Jeff
Mugen Seiki
Model Motorsports International
www.xrayraceway.com
www.tracksiderc.com.au
www.sellingstickers.com
Jeff Hamon is offline   Reply With Quote
Old 04-21-2010, 02:31 AM   #794
Hey Jeff,
jilles used a solid axle, not a oneway, i gues i have to change the checkboxes to make it more visible.
The setup do not change so much, its just a little bit more smooth driving in the short corners !! So i would say there is nothing to say about needed changes if you use the solid axle,
Alex
Old 04-21-2010, 03:15 AM   #795
Pro Models's Avatar
Hi Alex any idea when the light weight parts and solid axle will be available?
I saw that Ielasi had some prototype parts at last weekends Italian Championships any more info on what he used and what his comments were. He Tq'd so im sure the car worked perfectly.
Thanks Gus
Hey Jeff,
Alex
Pro Models is offline   Reply With Quote
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Sheperd Velox moy Nitro On-Road 585 04-19-2012 09:51 AM
Serpent 733 vs. Shepherd Velox V10 Geberit Nitro On-Road 27 07-06-2009 04:28 PM
Upgrade/ RCiD ryno1922 Nitro On-Road 26 03-31-2009 01:49 PM
Shepherd Velox V10 macaurc Nitro On-Road 31 03-02-2009 08:35 AM
