Old 03-16-2010, 04:11 PM   #736
Josh Cyrul's Avatar
Pro Models - I know Patrick and I used the stock clutch. I don't know if Jilles used a different one. Ielasi may have used his own but again I am not sure... Little things I think we are working on is the fit of the bearings in the uprights and possibly aftermarket parts to reduce spinning weight. Of course, if you know Alex and I we are completely nuts at wanting to test lots of things so really it just depends how much Patrick lets us go crazy...lol... Let's put it this way, it's little stuff that easily goes on the existing car - Nothing major as we already had a really, really good result the first time out.
Set-up sheet. I will work on asap!!
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 03-16-2010, 04:21 PM   #737
yes
coupe is offline   Reply With Quote
Old 03-16-2010, 04:39 PM   #738
Pro Models's Avatar
Hi Josh thanks for the info. Looking forward to having the upright bearing fit solved and also less rotating mass
Pro Models is offline   Reply With Quote
Old 03-17-2010, 04:29 PM   #739
nikoskar's Avatar
Shepherd Velox V10 Greek Gold Edition
If you want to see more pictures click here.
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 03-18-2010, 12:46 AM   #740
Send a message via MSN to PMSorber
Very nicely done!
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 03-20-2010, 02:18 AM   #741
itchy b's Avatar
NIce look!
I wonder if we will need to wear gold necklaces, watches and rings to race this one???
I was a little surprised that the body wasnt gold also!!!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 03-20-2010, 10:05 AM   #742
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Default front rim rubbing on shock balljoint!
Team shepherd! do u guys run the outside shock mounting hole on the lower arm? like the manual says.....with the shock mounted there the frnt rim will rub the balljoint at about 95% turn left or right...ive tried more than 1 style rim also... i had to dremel the balljoint plastic to almost nothing to stop the rubbing....i c on the gold edition v10 he has his frnt shocks mounted in the inner hole in the lower arm...wht do u guys do? how will handeling b affected with the shock mounted in the inner hole? thought ill ask since we still havent seen a single setup yet from any team drivers
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 03-20-2010, 06:43 PM   #743
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Yes, this is a problem. You will notice that on the only published team driver setup, Jilles runs them on the inside hole also. I tried different rims, different brand ball joints, and it still rubbed againts the rim.
But hey, Shepherd are quick to blow their trumpet about the pre-worlds and publish there results, and new team drivers, etc etc, but very quiet when it comes to supporting the average Joe driver, and addressing such issues. Its been 1 month, how hard would it be for one of the team drivers who regularly visit these forums to post a quick setup.
I had two V10s, I sold one, and have another brand new one in the box which I will sell shortly. I have gone to the 733, and the quality for an "Asian" manufacturered car is much much better then what this "German" built car is.
Shepherd RC | Brilliant RC | Arrowmax | Xtreme Aerodynamics | Matrix | Tectrade TTB
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 03-20-2010, 08:13 PM   #744
Nova how would you rate the 2 on performance.......honest opinion since you owned both......
Old 03-20-2010, 08:52 PM   #745
I believe every car has this issue at one point or another, wheels flex and the manufacturers are limited on space to design anything different. kyosho has since the car switched to foam I believe.
inner hole will stand the shock up more which is usually good for corner speed, it makes it stiffer since there is less leverage against it.
I was at the pre-worlds, the car looked amazing although I believe Xray has a little more to bring to the track in the future but Josh is well known for his creativity and now that he knows the track you should see some cefx parts shortly.
Support those that support us
http://ActivRC.com http://TeamPowersUSA.net http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 03-21-2010, 03:51 AM   #746
it hasnt been a month at all since the pre worlds at all, funny how the car people are driving is the best youve ever driven till you sell it for something else, i have never come across the perfect car yet and include the 733 in that.
the guys at shepherd have built a great car that has just proved its self to be competetive, i sent an email over to patrick at shepherd last week and had a reply within the hour, you dont get that support from any other manufacturer, so diss them if you like but i wont be listening any more
the snake has had its day, shepherd is the future
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 03-21-2010, 04:31 AM   #747
Geberit's Avatar
This is true, every car has some issues at some point. Remember 733 fuel tank and one way bearing! And the affair with rusty parts at Xray's NT-1 WC edition (read Xray forum) that was funny stuff to read
I think all the cars are grate and all have a issue or two but that's how it is with racing cars that are pushed to the limit.
And in my opinion the worse thing that a racing driver can do is to switch brands too often (every year). You lose all the set-up data plus new feeling for the car and new composition of elements (longer maintenance times)...
As I read this forums I see that the majority of posts are of a subjective nature and here and there you get a real objective statement served with real background! But anyway I like to reed all the stuff just to see how people over the world react.
Chears
Geberit is offline   Reply With Quote
Old 03-21-2010, 10:44 AM   #748
Chickentrader's Avatar
Chears
I couldn't find it on "Xray forum". Have you got a link?
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 03-21-2010, 11:03 AM   #749
Geberit's Avatar
Kindest regards,
Lars.
here you go: http://forum.teamxray.com/viewtopic.php?t=9734
Cheers
Old 03-21-2010, 01:57 PM   #750
DS Motorsport's Avatar
Has nothing to do with Xray, the guy states the parts were rust free when he got the kit, after a week some rust appeared.
If you put untreated steel in a damp environment for a week it will rust, even the super optimized special Xray steel.
Xray packs all steel parts with a special piece of paper which absorbs moisture so the parts won't corrode in the package.
I think the guys at Shepherd are doing all they can to give the drivers the best possible support, but at first they only had one car, now they have two so double the work but probably with the same crew.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Sheperd Velox moy Nitro On-Road 585 04-19-2012 09:51 AM
Serpent 733 vs. Shepherd Velox V10 Geberit Nitro On-Road 27 07-06-2009 04:28 PM
Upgrade/ RCiD ryno1922 Nitro On-Road 26 03-31-2009 01:49 PM
Shepherd Velox V10 macaurc Nitro On-Road 31 03-02-2009 08:35 AM
