Old 11-29-2009, 11:35 PM   #466
itchy b's Avatar
Originally Posted by Pro Models View Post
My v10 in action amazing day at the track
Sounds great although im sure we all would like to hear a more detailed description of your v10 outing!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 11-30-2009, 01:28 AM   #467
Vasilis's Avatar
I drove my V10 for the first time yesterday.
The car was really nice and easy to drive although the 2speed acted weird but I guess that was because the springs were new.
I had some issues and I would like to know if anyone experienced anything similar.
1. The drivetrain seems a little stiff and heavy, its not as free as the nt1 or even as the V8.
2. The pullies don't spin right. I think the adapters are a little of the center.
3. Why are the flywheel pins so thin? I broke one of the pins while trying to install it on the engine. I had to use my xray clutch on my first drive.
Vasilis
Shepherd Velox V8 eleven - RB C10
Shepherd Velox V10 - RB T10RC
Xray XB9 - RB BXR
Vasilis is offline   Reply With Quote
Old 11-30-2009, 05:15 PM   #468
Default First pictures
Hi,
I have received first pictures from Stephane BOUCHE, the new french distributor of Velox .
If you want to see, more and more to come here
JudgeFR is offline   Reply With Quote
Old 11-30-2009, 05:40 PM   #469
Just one ...
Old 12-01-2009, 12:26 AM   #470
hey guys good morning,
nice to hear that some guys still have weather to drive !!!
The drivetrain:
I think if take a little time while building it it gets better, i am sure, because i have no problem like that, and we also have no information about that.
If you find any problem let us know.
We made the drivetrain like it is because we liked to make the car durable for the normal user. For sure there is a way to lighten the drivetrain, but for the kits its a little to expensive. For the pro racers we will maybe make some special parts in the future.
The Pulley / Adapters:
I think, and i am worried about that, you are right !!! We donīt know what the problem is, but the adapters are for sure in center, but something went wrong. But anyway if you use the opposite grub screw to balance the adapters its getting perfect.And even if you do not do that the problem is not really effecting the driveability.
Flywheel pins:
Well, the pins are the same like in many other clutches.
And it is no problem.
The only problem is the kind people mount there flywheels !!!
I never use the tool to hold the flywheel at the pins to tighten the screw !
At any cluth this can cause problems, not only braking it, also you can bind the pins and the clutch do not work perfect anymore.
So use a big plier to hold the flywheel on the outside to tighten and untighten the flywheel screw.
Also we need to use the small pins as we do not have to much space for the cluth parts, and also the holes at the flyweights are smaller and the flyweights keep longer in place >> more durable !!
And at least one more thing about the 2-speed.
I think you need to check the assembly, maybe cut some burrs, or just run it a few minutes.
At the end i am sure you will be very satisfied with this 2-speed. If you adjust it one time you can be sure it will shift the same all the time.
So guys, keep us updated with anything, we will work on it as all the time.
regards
Alex
coupe is offline   Reply With Quote
Old 12-01-2009, 02:38 AM   #471
IQ0
IQ0's Avatar
hi Jilles, pls provide us with your Shanghai's set-up.
IQ0 is offline   Reply With Quote
Old 12-01-2009, 03:34 AM   #472
JGH
Here is my set-up of the Shanghai race 2009
This is for medium traction as it was cold at this race.
I don't have a scanner so I write my set-up down like below.
Front:
Shock oil: 650W 1 hole
Spring: white (long)
Diff oil 150.000
Camber left: 2.0
Camber right: 2.0
Toe-out: 1.0
Ride height: 6mm
Shock position inside hole shocktower
Shock position inside hole lower arm
Caster: 2mm clip front 1mm rear
Upper suspension arm lower position
Tyre: Matrix 35Shore
Droop 0mm under arm (end)
Rollbar 0 degree (flat)
Ackermann forward pos on servohorn, rear pos in topdeck
Shock oil: 650W 2 hole
Diff oil: 50.000
Camber left: 3.5
Camber right: 3.0
Toe-in: 3.0
Ride height: 7mm
Shock position second hole from inside hole shocktower
Shock position outside hole lower arm
Rollcenter position middle hole
2mm shim under upright
Tyre: Matrix 62mm Qual
Droop 4mm under arm(end)
Standard pulli 18T/19T/20T/25T
Gearing 16/22 54/59
Rollbar 1.8mm
Altis body
Orion Alpha Engine
Orion 2652 pipe
Capricorn clutch
2368 Ko Propo servo
Jilles
JGH is offline   Reply With Quote
Old 12-01-2009, 04:07 AM   #473
Vasilis's Avatar
Thanks for the reply Alex.
You should visit Cyprus. The weather is always nice. It rains a couple of times per year but when it does its always on raceday.
The 2 speed is just fine now. After some time and springs loosened up and the engagement was much better.
As for the drivetrain I didn't mean that the parts are heavy just that it wasn't spinning freely. I cleaned the bearings with some bearing oil and now they are spinning like crazy.
Vasilis
Xray XB9 - RB BXR
Old 12-01-2009, 04:23 AM   #474
itchy b's Avatar
Make sure you let us all know how it goes for you on your 1st raceday with the shepherd Vasilis!
EX1.5-SC10 4x4
Old 12-01-2009, 05:28 AM   #475
bighurt98's Avatar
Default Springs??
Spring stiffness??
Green
White??
Red??
Blue??
Is this correct stiffness order from softest to hardest?
Capricorn C03/Matrix Tires/Novarossi
Capricorn RC USA/RC Target
Murnan Modified Motors
Desoto Racing
Team Gravity
bighurt98 is offline   Reply With Quote
Old 12-01-2009, 06:42 AM   #476
musti72's Avatar
Hi Jilles,
Why did you use capricorn clutch, and how are your impressions about that clutch?
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 12-01-2009, 07:08 AM   #477
JGH
I had two engine at this race, one with capricorn clutch and one with the shepherd clutch. Both worked great in the qualifications. For the final I choose the engine who was newer and this was the engine with the capricorn clutch.
I will do more tests with both clutches later this month.
Jilles
Old 12-01-2009, 07:16 AM   #478
IQ0
IQ0's Avatar
thanks for the swift response, Jilles.
Old 12-01-2009, 09:29 AM   #479
musti72's Avatar
Jilles
Thanks for the fast reply, first of all. I have one more question: For how long do you use an engine until it gets older/slower compared to a new one?
Mustafa Alp
Old 12-01-2009, 08:28 PM   #480
shiston's Avatar
Vasilis
Come on Vasili, I sure Cyprus does some magic race days for you too
shiston is offline   Reply With Quote
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Sheperd Velox moy Nitro On-Road 585 04-19-2012 09:51 AM
Serpent 733 vs. Shepherd Velox V10 Geberit Nitro On-Road 27 07-06-2009 04:28 PM
Upgrade/ RCiD ryno1922 Nitro On-Road 26 03-31-2009 01:49 PM
Shepherd Velox V10 macaurc Nitro On-Road 31 03-02-2009 08:35 AM
