Shepherd Velox V10
#451
hey,
of course the weight depends on the equipment you use.
So you have to add the information completely.
Body, rims, battery, receiver and servos.
Patricks car is with the Audi body, Enneti light rims, KoPropo low profile, Ko spectrum receiver, the NimH battery and the personal transponder something around 1690gr.
We will have some additional weights as soon as we have some response about the weight.
We have enough space to add some weight, as so can see in the chassis, in the front it is already prepared to add a weight, and of course the battery tray could be replaced.
So we have the the lowest point of the car to add the weight !!!!
As soon as we know the medium drive ready weights from more cars we will do the weights.
regards
Alex
regards
Alex
#452
Thanks for the info on the weight Alex. Any one had a drive of their car yet any impressions ?
Noel
Noel
#453
Please someone put it on a track! Review!
#454
I can say that this has been the best 1/10 chassis i have driven to date. I broke our local clubs track record by .2 of a second first time out kit standard. The car was ballistic.
I have driven most cars around today and coming from an Xray i wasnt expecting anything superior however I was mistaken. Build quality was excellent and drive ability was impressive.
Well done Shepherd
Well done Shepherd
#456
V10 Cost
Hey Novarossi, Give Jeff at Trackside a call ( 0738897918 ) as he is the Australian importer for the Shepherd and I know he has ordered a heap of them and they're due any time. He might have a ball park price for you.
#457
Today the TRS nitro open race has started in Shanghai, China.
I'm overnight TQ with Fukuda only 0.03 behind me and Meen V 1.5 sec behind us over 5 min qualification. Tomorrow two more rounds followed by 45 minute final for the top 10.
I checked my car weight and it was 1655 gr.
These are my equipments:
KO Propo servo's 2368 (Normal profile)
2.4GHz receiver
Lipo 1100mAh battery
Blitz Altis body
60mm/62mm Matrix tyres
Orion pipe, Alpha engine
Regular air filter
So I must say the car is pretty light.
Most of the time you need to add extra weight.
Jilles
2.4GHz receiver
Blitz Altis body
Regular air filter
Jilles
#458
2.4GHz receiver
Blitz Altis body
Regular air filter
Jilles
2.4GHz receiver
Blitz Altis body
Regular air filter
Jilles
Can't make it to Shanghai, I am in freezing Beijing now!
Good luck.
Fukuda was there last year so he have some advantage but I am sure you will get better time tomorrow.
If all dry track and starting to get good traction, beware there may be traction roll in the final.
#459
Hi Jilles good luck for tomorrow, could you possibly tell us which 1100 lipo you are using.
Tks Gustav
Tks Gustav
#460
Hello guys,
Just small update about the race today.
Fukuda TQ with 19 laps in 5.15.9
Jilles 2nd with 18 5.01.1
Meen 3rd with 18 5.03.0
In the final it was a close battle between us three but after 10 min I ran out of fuel so the race was between Fukuda and Meen.
On the end Fukuda won by 12 sec in front of Meen and I was 4 laps down as I ran out of fuel twice!
Track was very nice and great thanks to Rick Wang for the organisation of the TRS race.
Set-up will follow later.
Jilles
Jilles
#463
Hey,
well thats not that easy to answer !!
The ackerman effects more in the corner, not that extremely much in the first point of the corner. For the really first point of the corner i would say the front toe out and the car setup is more relevant. But in the corner the ackerman is the man.
To explain it simple, the more forward you are, the more aggresiv the car becomes in the corner, while you lose a little bit on exiting the corner !!?
So what you have to do is >>>> try it !
It depends also so much from your driving style and the complete car setup.
Try it, and do not forget to readjust the toe out inthe front after you changed the ackerman position !!! A common mistake wich will ruin the effect !!
regards
Alex
regards
Alex
#464
Thanks! I've seen the two positions on the T2009 and almost all setups I have seen have been back. On the RRR I run, at Kissimmee, because it is big and flowing, I would run the C position on newer car or the 10 ackerman which made the steering links longer. I consider the steering link as the radius of a circle and the shorter the link is, the more quickly the turn-in or the faster you get to full lock or quicker transtion to scrubbing speed. Being longer, it travels the same distance, but it slower to get to full lock therefore smoothes out or slows down how quickly the car transtions from going straight to turning and scrubbing spend at corner entry to mid corner. It seems to allow the car to maintain more of the corner speed and making each corner time a bit shorter.
I also like the smoother feel on my driving style.
Thanks for input!
Thanks for input!
Hey,
regards
Alex
regards
Alex
#465
My v10 in action amazing day at the track
